Old 09-16-2003, 06:34 PM   #1
69K10 Tank
Question My bed is biting my cab (frame flex)
Anyone who 4wheels a 67-72 chevy know how much the frame flexes. Well mine is doing it so much that the top bolts that hold the bedsides on are gouging and denting the cab when it flexes. My question is, how can I stop this? Cause I really don't want to keep beating up my cab. Any thought would be appreciated. Thanks
69K10 Tank is offline   Reply With Quote
Old 09-16-2003, 06:40 PM   #2
GreenMystChevy
I don't know how effective or safe it would be but you could think about putting some sort of large, homemade rubber washer between the bolt and cab. Something softer than a bolt but hard enough not to rip or tear out.
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall
GreenMystChevy is offline   Reply With Quote
Old 09-16-2003, 06:59 PM   #3
wildwood
wildwood's Avatar
Loosen the bolts to your box, pull the box as far back as you can. Then tighten them up again. If thats not enough, you'll have to reem the holes longer or drill new holes futher back. You might have to move your bumper back as well. Good luck, hope this helps.
You can't get out if ya don't get in
wildwood is offline   Reply With Quote
Old 09-17-2003, 08:10 AM   #4
HeavyK20
HeavyK20's Avatar
Are your cab mounts rotted? If the rubber is cracked and broke down the cab might be sagging.
Eric
1969 K20, 465/205 package
HeavyK20 is offline   Reply With Quote
Old 09-17-2003, 08:12 AM   #5
CUSTOM/10
CUSTOM/10's Avatar
I drilled new holes about 1" further back on all the brackets were the bed mounts to the frame, this corrected the problem for me.
Hope this helps.
CUSTOM/10 is offline   Reply With Quote
Old 09-17-2003, 06:16 PM   #6
J.Lance
Too many is never enough!
bed
In addition to moving the bed back, if you still have hex head bolts on the header, replace them with the phillips pan head bolt used on a lot of the beds.
Jason
1968 K10 SWB Fleetside
1971 K2500 GMC LWB
1968 K20 (later frame, donor body)
1972 C20 LWB parts truck
1993 K2500 Suburban, tow rig, 454, 4L80E
NEW!! 18' Siem's car hauler
2004 Honda Odyssey (family man!)
J.Lance is offline   Reply With Quote
