Old 07-15-2011, 06:49 PM   #276
BruthaMan
US Army Veteran
BruthaMan's Avatar
Re: Project Pancho Villa - 1978 SWB
Thanks 3r!c84. It was tough to let go of the money, let me tell ya! Everyone seems to swear by them. Compared to the little Dart heads I had on before (which were respectably fast with the XE268 cam), these should really open her up!
One more pic. Air Gap intake is back on with one valve cover. Calling it a day. Bruh'man ain't used to this heat!
BruthaMan is offline   Reply With Quote
Old 07-17-2011, 12:48 AM   #277
MTCK
MTCK's Avatar
The truck looks amazing! Great build! Too bad about the weather - I always do better with cold then hot (obviously). Happy Wife, Happy Life!
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 07-17-2011, 03:01 PM   #278
juiceman650
juiceman650's Avatar
Awesome truck man, just finished going through the whole thread. One question though, what year is it again? Can't wait to see more updates on this one, keep up the great work!
juiceman650 is offline   Reply With Quote
Old 07-17-2011, 03:20 PM   #279
BruthaMan
US Army Veteran
BruthaMan's Avatar
Thanks guys!
The truck is a 1978.
We're about to put the intake on, hook up the headers, distributor, then maybe start on the vintage air install today. More pics later today.
Old 07-29-2011, 11:47 PM   #280
BruthaMan
US Army Veteran
BruthaMan's Avatar
I have a ton of pics and will have a video of the startup sometime tomorrow.
Motor is rebuilt and we did a quick fireup tonight. Man, it sounds mean!
We're going to do the cam break-in, tomorrow morning around 10am (give the neighbors time to sleep in).
I'll shoot a video of the startup and exhaust. I have some pics of the Vintage Air install as well. We have a few more pieces for it, but overall it's been fairly straight forward.
Two of the AC hoses will need to be crimped, and it needs to be vacuumed, so will probably take it in for that once everything else is finished. I don't have the tools for that and not sure I want to invest in them, for a one-off setup.
Old 07-30-2011, 11:57 PM   #281
77BBGMC
77BBGMC's Avatar
Just read through the build, impressive!!
77BBGMC is offline   Reply With Quote
Old 07-31-2011, 07:43 AM   #282
73gmc454
73gmc454's Avatar
I've spent my morning reading the complete build , Wow you did alot in a short time frame , everything looks great , those AFR's should wake upthat small block !
my build 77 gmc shortbed big block, http://67-72chevytrucks.com/vboard/s...d.php?t=438237
73gmc454 is offline   Reply With Quote
Old 08-02-2011, 02:48 PM   #283
BruthaMan
US Army Veteran
BruthaMan's Avatar
Thanks guys!
Some more pics:
Hughes 2400 Stall Converter to replace the stock one:
Comp Gold roller rockers on the new AFR heads:
Three boxes from Vintage Air:
Individual components from the Vintage Air Gen IV kit:
Chrome Sanden compressor, with a Billet Specialties cover:
Old 08-02-2011, 02:55 PM   #284
BruthaMan
US Army Veteran
BruthaMan's Avatar
The Gen IV kit comes with steel brackets. Nothing fancy, can be painted. Ordered AC and Alternator brackets from Billet Specialties:
Here's the AC face plate that replace the stock controls:
Finally, here's a video of the startup after the heads/cam swap:
Still on the to do list:
Finish the front grill install.
Truck to the AC shop to have the hoses crimped and system charged.
Detail the engine compartment.
Definitely going to have to look at running dual exhausts. The beast is loud. We did a mild test run yesterday. Trans fluid was a bit low and it was slipping, but it sounds like a race car.
May go with long Magnaflow mufflers, then run a turbo muffler before those, to quieten it down. I don't think a single muffler will do it, though I'm looking at all options right now.
Old 08-02-2011, 03:16 PM   #285
MTCK
MTCK's Avatar
Sounds good! Sounds angry! Can't wait to see it tearing up the asphalt...
-Marcus
Project Plow Truck
Old 08-02-2011, 03:52 PM   #286
77BBGMC
77BBGMC's Avatar
Sounds good!
Old 08-02-2011, 06:19 PM   #287
bluex
bluex's Avatar
It sounds good, send that corsa muffler my way if you dont want it!
bluex is offline   Reply With Quote
Old 08-04-2011, 08:16 PM   #288
BruthaMan
US Army Veteran
BruthaMan's Avatar
The Corsa mufflers sound very good on it. On one hand, I love the sound. It is unlike anything else and sounds like what you would expect a race car to sound like, when you open it up. On the other hand, it's just too loud at my age, for how I want to use the truck.
An update, but no photos. Pete added a trans cooler with it's own fan, in front of the condenser. Put the rear of the truck on stands and let it run for a while to get the trans fluid circulated and the torq converter filled.
And then we took it out for a ride. I cannot even begin to describe the difference the heads and cam swap made. Mostly the heads, because the cam was just a little bigger. OMG, those AFR heads brought Pancho to life!
It was unbelievably fast and I didn't even take it to WOT. Scary fast. Pete said he thought it could hang with his '03 Vette, easily.
My face hurts, I was smiling so much! Still reeling from the adrenaline rush!
Old 08-04-2011, 10:13 PM   #289
baclay9
What trans cooler did you go with?
baclay9 is offline   Reply With Quote
Old 08-05-2011, 12:23 AM   #290
BruthaMan
US Army Veteran
BruthaMan's Avatar
Trans Cooler and fan are Hayden.
Old 08-05-2011, 04:27 AM   #291
juiceman650
That exhuast sounds awesome man, and the Vintage Air system looks sweet!
Old 08-06-2011, 01:10 AM   #292
bluex
bluex's Avatar
I understand that, I dont like them quite as loud as I used to either. I doubt I'll be able to afford them, but keep me in mind if/when you get'em off...
Old 08-07-2011, 06:31 PM   #293
80streetcoupe
BruthaMan, what a beautiful truck. I just spent the last hour reading your build from the start and I thought the truck was nice in stock shape as is. Beauty is only skin deep untill you peel back the layers...haha!!!
You did an awesome job on her and what a great tribute to your friend. Run the wheels off of it and I am sure your grandson will be by your side riding shotgun with "paw paw"!!
Again, great job on your '77 Chevy!!
80streetcoupe is offline   Reply With Quote
Old 08-21-2011, 04:45 PM   #294
tattoed71
tattoed71's Avatar
just bought a truck off of bruthaman and got to scope out this truck the pics dont do this truck justice. all i could say is wow, i love the steering wheel, wasnt even thinking about the ex cab chevy i bought from him to tow my 1971 around i just keep thinking of that steering wheel. thanks for the truck did good coming home, now its parked under the carport for the next few months till someone needs it, thanks again brother
tattoed71 is offline   Reply With Quote
Old 08-21-2011, 04:48 PM   #295
BruthaMan
US Army Veteran
BruthaMan's Avatar
Hey, it was good to meet you, bro! Glad to hear you made it home OK. Knew you would, that truck is solid as a rock! Good luck on your 71, sounds like you are going to do it really nice!
Old 03-26-2012, 01:35 AM   #296
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Any news?
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 03-26-2012, 05:43 AM   #297
my4by2
my4by2's Avatar
Beautiful build man! Can't wait to see the finished product!!!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 03-26-2012, 08:45 AM   #298
78BO
78BO's Avatar
LOL, I remember that feeling. I'm not wanting to start an argument on which carb is better, but I'd be willing to be if you took that edelbrock off and put on a holley, you'd be even more impressed. I had a 750 edelbrock on my 383.
While it ran like a bat out of hell, it just seemed like there was more there. I installed a 770 avenger and all I can say is WOW! The throttle responce was 100% better. The only down side to that is with the shaky engine you have to retune the carb every now and then.
But as for the truck, that thing sounds great. And looks good too.
1978 Chevy C10 Bonanza, 405hp/440tq 383, tweeked Th350.
http://www.facebook.com/#/profile.ph...&id=1116781152
78BO is offline   Reply With Quote
Old 03-26-2012, 12:29 PM   #299
Dieselholic92
Dieselholic92's Avatar
What brand of headers are you using on you truck?
Semi professional heavy equipment operator
Amateur mechanic
Dieselholic92 is offline   Reply With Quote
Old 03-26-2012, 09:34 PM   #300
BruthaMan
US Army Veteran
BruthaMan's Avatar
Thanks for the kind comments. The headers are Hedman.
Rebuilding the motor for the third time. When we added the AFR heads last time and bumped the cam up to a Lunati 284, it was too much. I know, I know...there's not such thing, except that the idle is far too lopey and it's a bear to drive the truck with all that power.
So, we're bumping the cam back down to a Comp xe 264, but this time using a roller retro kit.
I've diverted my attention to a recent 72 CST/Longbed that I'm going to use as a daily driver. It's running good, just doing some "personal" touches to the 72.
