Old 03-26-2012, 02:56 PM   #1
savatreatabvr
savatreatabvr's Avatar
BBC Rocker Arm Nut Loose!
I have a intake rocker arm nut that keeps loosening my mid 70's 454! What could be the problem? Could the nut be cracked, is that even possible?
savatreatabvr is offline   Reply With Quote
Old 03-26-2012, 03:01 PM   #2
esbstuff
Re: BBC Rocker Arm Nut Loose!
Yep the nut is bad! They are only .37 each at the local napa. you are time and money ahead to replace all 16 while you are in there...
esbstuff is offline   Reply With Quote
Old 03-26-2012, 04:46 PM   #3
INSIDIOUS '86
INSIDIOUS '86's Avatar
Look up polylocks. won't have that issue ever again
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 03-26-2012, 06:40 PM   #4
savatreatabvr
Ok, I pulled the valve cover again and inspected the rocker arm nut and as far as I can tell it's NOT cracked! I also inspected the rocker arm, rocker arm stud, push rod and rocker arm ball/fulcrum and everything appeared to be in proper working order! What's funny is over the years I've overheated, run out of oil and blew up SBC & BBC engines but I've never ran across this situation before. I think I'll just go get a nut hope for the best! Wish me luck!
Old 03-26-2012, 06:51 PM   #5
rwhit57
rwhit57's Avatar
It's been awhile since I've had a BB but I think it would have screw in studs. If not make sure the stud isn't backing out. A simple fix to that nut is set it where it needs to be then take a punch and ding it by the stud, makes it like a lock nut.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 03-27-2012, 02:34 PM   #6
savatreatabvr
Excellent advice, I wished I would have done that before putting the valve cover back on!
Old 03-27-2012, 04:08 PM   #7
INSIDIOUS '86
The nuts for the rockers are friction nuts. Chances are they have just worn out over the years not to mention the stud can wear too
Old 03-27-2012, 05:16 PM   #8
russgt
russgt's Avatar
Install a set of polylocks, problem solved
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
