Old 03-27-2012, 06:36 AM   #3026
Low Elco
Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
Drew, did those seats go nin fairly easy, or was quite a bit of fab required? Looks great!
Low Elco is offline   Reply With Quote
Old 03-27-2012, 07:08 AM   #3027
dlturner00
Thumbs up Re: ** YOUNG FRANKENSTEIN ** The truck Chevrolet should have built.
I've been following this build for quite awhile and as everyone else has said, awesome job! You have me motivated to get started on mine. My brother has been in the body shop business for 40 yrs. so I know what kind of skill it takes to do something like this. You are truly a master craftsman. I hope I can get to Pigeon Forge, but if I don't, I may just cruise to Memphis someday. I'm only a couple hours away. I would really like to see your truck in person.
David
69 C10 LWB (SWB now)
dlturner00 is offline   Reply With Quote
Old 03-27-2012, 08:52 AM   #3028
drewskiren
Lucky Teter at the wheel
drewskiren's Avatar
The seats are bolted directly to the floor and I have a post showing exactly where to drill the holes.
Drew
YOUNG FRANKENSTEIN (Finished with MAJOR Surgery - IT'S ALIVE!!!)
The Bride is currently under the knife!
drewskiren is offline   Reply With Quote
Old 03-27-2012, 11:55 PM   #3029
drewskiren
drewskiren's Avatar
I worked on my hide-a-dash tonight and welded studs to the mounting plate. Here it is just sitting in the glove box hole. I need a plexiglass faceplate and I will cover the green metal in upholstery.
The idea here is to have all the modern information available, but usually out of sight behind the glove box door.
Drew
Old 03-28-2012, 12:39 AM   #3030
68 TT
Still plays with trucks
68 TT's Avatar
Why not cover the whole thing with a single piece of plexi with the area over the metal painted black from the back side so it blends in with the gauge face.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 03-28-2012, 12:45 AM   #3031
mcmlxix
Collector of Projects
mcmlxix's Avatar
You should add a fake steering wheel on the passenger side... just to mess with everyone....
Rich
1972 K5 Blazer CST Click HERE
Old 03-28-2012, 07:45 AM   #3032
ERASER5
ERASER5's Avatar
Snicker! One that can be pulled off and make scary faces at other drives with the detached wheel in hand! It will take them a second to rember wich side the driver is on.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 03-28-2012, 09:08 AM   #3033
drewskiren
drewskiren's Avatar
I can't get to the backside to mount it, but with the metal plate and studs I can put it together on the bench and then mount the metal plate from the front. A picture will help visualize when I finish it.
Drew
Old 03-28-2012, 09:25 AM   #3034
67cheby
67cheby
67cheby's Avatar
cool idea, will any of the guages on the drivers side work also ?
67cheby is offline   Reply With Quote
Old 03-28-2012, 11:03 AM   #3035
drewskiren
drewskiren's Avatar
Eventually when I can afford it, yes.
Drew
Old 03-28-2012, 11:20 AM   #3036
67cheby
67cheby
67cheby's Avatar
i see !
Old 03-28-2012, 04:18 PM   #3037
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work Drew! For the older gauges, can't you just install the factory sensor and oil pressure line in ports in the engine? Or are there no extra ports on these newer engines?
Ryan
1969 Chevy milk truck
Old 03-28-2012, 06:40 PM   #3038
drewskiren
drewskiren's Avatar
Yes, oil pressure can be tapped off of a plate on the engine. Volts are also easy. Spedo is not. Gas gauge is not.
Drew
Old 03-28-2012, 09:49 PM   #3039
drewskiren
drewskiren's Avatar
I hope that you can't tell what I have done today.
Invisible bra for the rock chip prone hood.
And I'm legal now!
Drew
Old 03-28-2012, 11:30 PM   #3040
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Sweet, I really like that idea!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 03-29-2012, 12:10 AM   #3041
mcbassin
Still Learning
mcbassin's Avatar
Looking great Drew!
Old 03-29-2012, 02:22 AM   #3042
Dieselwrencher
ID tag looks great! You didn't remove it did you?
Ryan
Old 03-29-2012, 08:43 AM   #3043
drewskiren
drewskiren's Avatar
Of course not! I pulled the edges up slightly so I could fully sand and paint behind it.
Drew
Old 03-29-2012, 09:10 AM   #3044
jeffg1010
jeffg1010's Avatar
Originally Posted by drewskiren View Post
And I'm legal now!
hmm.... not sure if those weights are correct ... anymore
Jeff
1972 Blazer CST 2wd- My son Sam's Project "S" Project "S"
1970 Suburban - SOLD "One Bad Burb" Photobucket Album
1986 C30 Crewcab - 63K original miles, original paint
Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP...
jeffg1010 is offline   Reply With Quote
Old 03-31-2012, 09:47 AM   #3045
drewskiren
drewskiren's Avatar
Really bummed, but I think I was sent the wrong carpet set.
I ordered a high hump kit and it says on the box it is for the "400 transmission", but its too short in the front from side to side. The rear of the front piece seems to be wide enough (pics 3 &4) but the front that goes over the high hump ends up being 2 inches too narrow at my passenger kick panel.
Do you think they will send me a replacement?
Drew
Old 03-31-2012, 09:56 AM   #3046
lolife99
67-72 parts collector,…
lolife99's Avatar
The last carpet kit I got was about 2" too long at each door opening.
It had to be trimmed to fit.
I believe it came from Brother Truck Parts. (not sure of the brand)
I would send that back.
Order for a 4x4 burb or 4spd manual trans and you will get the high hump version for sure.
Most companies just specify low hump or high hump.
Keith
Convert to disc brakes.
Old 03-31-2012, 05:41 PM   #3047
48richard
48richard's Avatar
Interesting. Last year I bought a carpet from ACC for my low hump, and it was too full over the hump. I ended up putting a couple of extra layers of padding over the hump to fill it out. Looks like their molds aren't too accurate.
1971 C10 Longbed, 350/TH350
48richard is offline   Reply With Quote
Old 03-31-2012, 09:25 PM   #3048
MAC71
MAC71's Avatar
About 6 years ago I got the ACC carpet for my 72 suburban with the high hump. It was also about 2 in to short on the ends. I sent it back and the next set was about 1/4 inch to short. Same carpet number on both sets. Everything in the back fit really well.
Mike
1971 C10 350
1969 C20 396
1979 Corvette L-82
MAC71 is offline   Reply With Quote
Old 03-31-2012, 09:25 PM   #3049
72 tigger
72 tigger's Avatar
ACC has always been known to make nice replacement carpets- hope they work with you
72 tigger is offline   Reply With Quote
Old 03-31-2012, 10:23 PM   #3050
68 TT
68 TT's Avatar
I had the same problem with them on two different cars. Too short up front.
Not quite as short as yours so my sill plates just barely covered the edge of the carpet (like 1/16" under the edge barely).
I should have sent them back as the edges come out from under the sill plates when I vacuum the car out.
