#526 |
"Where were you in '62?"
![]() Join Date: Jul 2004
Looking Good!
I ran across this several weeks ago and forgot to post it on here when you started to mock it up. http://www.thehollisterroadcompany.c..._Firewall.html ![]()
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
#527 |
56 - autocross
Re: My 57 Pro Street
Kim:
That looks great. How did you bend the radius on the straight piece? What gauge did you use? Is that piece overlapped on the firewall? If so, will you just fill it? |
#528 |
A320 Pilot/USAF Retired
Looking good!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
#529 | ||
I used 16 gauge. The piece is cut to fit flush with no overlap. Thanks. Kim |
#530 |
Tripple Five Fanatic
Once again, great job on the firewall.
Tri5
1955 Chevy Stepside/LS1 drive train http://67-72chevytrucks.com/vboard/s...d.php?t=371513 |
#531 |
Yep, looks real good.
![]() All the fab work is sweet. ![]() What flavor of headers are you gonna run? Looks like you have enough clearance for some long tube headers. Well it want be long and you will be ready to you fire that bad boy up! Hey, Look into Joe Gibbs oil for GM LS engines.
#532 |
Why spend so much when you can get the german Castro Synth 0-30 for half the price at AutoZone, lots of talk about that on the LSx boards. Make sure it's the bottle that says bottled or made in Germany.
Tri5
#533 | ||
Thanks.
I can get them in the $400 range. Not sure if I want to pay the extra cost of the long tubes at this time. Quote:
Kim |
#534 |
looks great, how far back is the piece you built?
#535 |
Thanks.
It's set back 3"s. It gives me about an inch of clearance behind the intake. Kim |
#536 |
Certified Car Nut
Kim,
Once again you did a great job on that firewall everything is looking top notch. |
#537 |
Looking good! I like seeing others progress. It helps me get going. You have mad fabrication skils.
55 2nd series Chevy Pickup 2019 Chevy Equinox(Daily driver) 2011 Chevy Malibu (Wife's car) MSRA Member I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose. -George Carlin |
#538 | ||
I'm like you I get inspiration from seeing what others on the board do. Kim |
#539 |
Firewall is looking great!
Those curves sure are eye appealing! Brian Posted via Mobile Device
current project; 1950 GMC "Junk Yard Dawg" http://67-72chevytrucks.com/vboard/s...d.php?t=635960 ___________________________________________ SOLD to "ONEBADFIVEFIVE" http://67-72chevytrucks.com/vboard/s...d.php?t=436406 |
#540 | |
Kim |
#541 |
that is nice work kim
![]() i had to enlarge the stock recess to get my hei dist to fit i've seen part of a wheel barrow tub welded in there too
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#542 | |
I've seen the wheel barrow done also and thought about it for a while before doing what I did. Kim |
#543 |
excellent work kim - you really have it workin out nicely !
#544 |
Kim,
I gotta say this is one of the slickest builds on the forum. You are a metal magician. I've gotten a lot of ideas from your build
2006 Chevy Silverado 3500(Duaramax/Allison) - DD 1997 Honda Civic - Work Beater 1981 Chevy Malibu - Race Car 1959 Chevy Truck - Project http://67-72chevytrucks.com/vboard/s...d.php?t=481442 2006 Honda Accord - Wife's ride |
#545 | |
I get a lot of inspiration and ideas from the guys on the board also. Kim |
#546 |
A little up date.
I needed to make my trans hump so here's what I did. I made a frame out of some round stock and then made some templates out of heavy card stock. Kim |
#547 |
A little welding, bending and grinding and I have something that will be hidden by a center console and carpet.
I'm waiting on some headers to see if they're going to fit before I get the cab back off to finish up the firewall. Kim |
#548 |
Better to have it and not need it, then to need it and not have it. Fork In The Road....Cummins Build My Build Thread... Alternative A/C Mounting for LS Engines 4L60E Transmission Rebuild Info Trailing Arm How To |
#549 |
56 - autocross
That's nice! When can u start on mine?
#550 |
Thanks.
Thanks. i can start yours on the second Tuesday of next week. Kim |
