03-30-2012, 06:53 PM | #1 |
C35 Crew Dually
weird starting issue
I'm not sure how to even explain this issue as it's very weird.
most time my truck starts amazing for an old carbarated truck (even on cold days and not having the choked hooked up) but some times it has a hard time starting and if it does start it spits and sputters and some times quit the only "cure" for it is to rev it till it "clears up" and then its fine....it's very weird and I would like to get it fixed so ppl don't stare at me when I start it up and have to rev it to get it to run right lol.
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
03-30-2012, 07:02 PM | #2 | |
Canadian Trucker
Re: weird starting issue
2020 Silverado Trail Boss - 6.2/10spd |
03-30-2012, 07:04 PM | #3 |
C35 Crew Dually
any time when it feels like it of course. like some times it when its sat over night it will start up like it was just run the next time it runs like a bag of SH*T. same with when its warmed up.
03-30-2012, 07:21 PM | #4 |
Robert Olson Transport
thats a choke problem
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
03-30-2012, 07:24 PM | #5 |
C35 Crew Dually
03-30-2012, 07:27 PM | #6 |
Canadian Trucker
Why is your choke not hooked up?
03-30-2012, 09:20 PM | #7 |
C35 Crew Dually
you really wana know? because it was wired to my gas gauge and I can't find the one its actually suppose to hook too hahaha
03-30-2012, 09:29 PM | #8 |
Canadian Trucker
Oh, have you thought about putting a manual choke on?
Is your trucks choke controlled by power or hot air?
03-30-2012, 09:35 PM | #9 |
C35 Crew Dually
power i believe and yes i have considered it how hard is it to do?
03-30-2012, 10:23 PM | #10 |
Canadian Trucker
I'm not a 100% sure but I think the easiest way is to find a manual choke carb, then run a choke cable into the cab. Though I think you can get a kit to switch you electric choke to manual.
03-31-2012, 01:20 AM | #11 |
what year is the truck? as if it has the egr it may be open at the wrong time (sticking) or may be plumb wrong vac at cold not hot off of the thrmo swicth. just my though as that is what mine did and i too have the choke wired open starts fine and will run fine after a few seconds on a high idle.
03-31-2012, 10:30 AM | #12 | |
C35 Crew Dually
03-31-2012, 10:41 AM | #13 |
does it have the ing box in the cab? it would be behind the glove box if it did. akso what cab do you have? thinking a stiking float??
03-31-2012, 10:50 AM | #14 |
C35 Crew Dually
Nit sure but I dont remember seeing one when I re did the harness. my cab is an 87 3/4 crew cab
04-07-2012, 09:07 PM | #15 |
Do you have the Rochester q-jet,that has the electric metering solenoid on top? If so,you'll want to replace the carb with an earlier one. When the solenoid screws up,it can cause the problems you're having,or worse! A new solenoid(if you can find one),is expensive and difficult to tune in.Mine went bad,and I used 3/8 tank of fuel to get 2 miles home!Had to change the plugs,carb,gasket,oil,and filter!
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect ! I'm busier than a one-legged cat,in a sandbox! Veteran..and proud ! I can't fix what ain't broke....you want I should break it? |
