71 c10 two peice or solid drive line
i was wondering what is better when lowering 71 c10 1/2ton im going 5 inch springs in rear 2 inch springs in front with 3 inch lowering spindles ,, and then 2 inch blocks in rear .,. but wanted to know what is better 2piece driveline or a solid one ?,,, if i need to change drivelines im changing trannys from 350 to 400 ,,
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: 71 c10 two peice or solid drive line
I prefer a 1-piece drive shaft.
short / long bed ?
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
#4 | |
![]() Join Date: Mar 2005
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
Gearhead
I have a one piece drive shaft in my 72' C10 SB, but I also have a 700R4 so its not terribly long. I think for extreme lowering I would prefer a two piece unit so that the cab and trailing arm crossmember dont have to be raised to reach the axle at full dump. Im sure there are advantages/disadvantages to both....
2002 Saturn SL2, My D/D 2019 Ford Fusion SE, Ecoboost - Wife's D/D 1993 Camaro Z28, A4, CAI, Cat-Back Exhaust Project C10 (my 72' C10 w/96' LT1, 700R4, bagged F&R, 18's (for now), Short/Fleet) -- SOLD! Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=313644 |
its long bed , im gonna go stick the springs in it in a litte bit and then im gonna order either the 2.5 or 3 inch front spindles ,,
CHEVYRESTOREGUY what size are those rear tires in your pic ,, i have a 56 and want to get around the same size ,those look bad aSS
In my avatar, the truck had the old wheel/tire combo. Those were 29x15.50-15 Mickey Thompson Sportsmans on a 15x10 magnesium Torq-Thrusts. The rims were too narrow for the tires, so the sidewalls were really swollen. I sold the wheels to a guy in Pennsylvania who is building a '57 Chevy gasser, and I sold the tires to a local guy who is building a T-Bucket.
Currently, the rear tires on the '55 are 29x15.50-16 Hoosier radials. They had them on closeout for $80 each (!) so I bought 2 sets. I guess they weren't big sellers because of the 16" diameter. The rims are ET Fuelers 16x12 with a 5" backspace. My build thread shows much better pictures of the old and new combo. One of these days, I'll get back on that truck.........Gotta finish my '64 parts runner first.
I always prefer a one piece shaft, even if I have to compromise top speed in order to have it.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
so does at mean you have another set just laying around ? haha .. hmmmm
Old member
A good drive line shop can make a double shaft as good are better than a singal. I had my first one done about 1990 when I installed the 700-R4.
I had to have it cut and rebalanced with a new carrier bearing installed. I had the carrier redone about 1 year ago now. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
