Old 09-17-2003, 10:24 PM   #1
Porkchop
Porkchop's Avatar
S10 frontend
I heard from someone that S10 front end parts would fit on our year trucks. Is this true? would there be a lot of mods? would I be better of just swapping in 72 parts?
thanks for any information
brad
Porkchop is offline   Reply With Quote
Old 09-18-2003, 11:04 AM   #2
lost wages
lost wages's Avatar
im not sure what the advantage would be, the tried and true method of using 71-mid eighties front end parts would seem to be the way to go unless your wanting a small bolt pattern or something, what are you planning on doing.
lost wages is offline   Reply With Quote
Old 09-18-2003, 04:52 PM   #3
Porkchop
Porkchop's Avatar
I have a 69 3/4 ton and I just can't seem to figure out how to get what I want. I don't want a slammed truck I just want it lowered to give it a fast muscle or street truck look. Also, I want either a 6 or 5 lug pattern instead of the 8. I just don't know how I should plan on doing this the best way.
thanks for your help
brad
Old 09-19-2003, 04:40 PM   #4
mcmlxix
Collector of Projects
mcmlxix's Avatar
you should be able to use 71-87 front end parts to get 5 lug disc brakes. Use stock spindles and a 1-2" drop spring or stock springs and a drop spindle. The rear is just a set of drop springs.
That should leave you lower, but not too low. You will have to do something with the rear. I am asuming you have a rear coil spring setup. Either find a rear from 71-72 or get new axles.
Rich
1972 K5 Blazer CST Click HERE
Old 09-20-2003, 09:55 AM   #5
Porkchop
Porkchop's Avatar
Thanks for the reply. I have rear leaf springs. At what point did rearends change width so that I know where to look for one.
thanks again
brad
