Old 09-18-2003, 12:24 AM   #1
67cst
i love summertime
67cst's Avatar
back firing
hey guys, the 71 that i got 2 weeks ago is running good but i notice when im climbing a hill or giving it a fair bit of gas it back fires a bit, not loud at all, more like a pop, it seems like its miss firing almost, what is causing this? should i put some new plugs and wires in? would it be the propane maybe...ive heard when its cold propane can act weird...any suggestions would be great
thanks, Derek
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 09-18-2003, 10:42 AM   #2
hgs_notes
GEARHEAD
hgs_notes's Avatar
I'd check the timing and make sure the vacuum advance is hooked up and working.
HG
hgs_notes is offline   Reply With Quote
Old 09-18-2003, 02:02 PM   #3
tom hand
CCRider
tom hand's Avatar
Re: back firing
I'ts cold up there already? Propane will not tolarate cold at all, so here's some simple things to check. Make sure your radiator is full...if it is low it will starve the vaporizer of water and the propane will start to freeze up. What temp is your motor running at? If it is running pretty cool, [less than 185] step up to a warmer thermostat.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 09-18-2003, 03:24 PM   #4
67cst
i love summertime
67cst's Avatar
thanks for the ideas and stuff to check guys, it isnt too cold up here yet but i can see my breath outside at night or in the late afternoon...
Old 09-18-2003, 03:33 PM   #5
John Fabris
TOTY 2006
John Fabris's Avatar
How old are the plug wires?? Anytime you have an engine that runs good in a non load situation (in park or neutral for example) but then starts to studder and pop under a load (in drive, or your case uphill) the first thing you should check is the plug wires....
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 09-18-2003, 03:51 PM   #6
67cst
i love summertime
67cst's Avatar
thanks john, ill check them today, im sure they should be replaced along with plugs...ive never owned a propane vehicle before, is there anything weird i should know, like the plugs wouldnt have a different gap or anything would they?
Old 09-18-2003, 05:58 PM   #7
lukecp
Formerly yellow72custom
lukecp's Avatar
I would just give it a full tuneup and check for vaccuum leaks.
No clue on the propane spark plugs......
How is the MPG and operating cost compared to regular gas?
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 09-18-2003, 06:33 PM   #8
70cst10_05
70cst10_05's Avatar
check dist. cap for cracks, mine did that for about a week, it would barely pull itself up a big hill
1970 Chevy CST/10
1970 Chevy CST/10
1972 Chevy C/10
1972 Chevy Suburban K/10
2019 Silverado 2500 Duramax
Kevin
70cst10_05 is offline   Reply With Quote
Old 09-18-2003, 07:26 PM   #9
67cst
i love summertime
67cst's Avatar
thanks and thanks for the ideas, i have no idea what mpg i get on the truck....
Old 09-18-2003, 09:48 PM   #10
dinnut
dinnut's Avatar
what? propane trucks? im confused... you use propane?
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
