Old 04-05-2012, 04:46 PM   #1
dave666693
dave666693's Avatar
Poly tank hose size?
I have a poly tank that the filler inlet is 1 1/4 OD. The Blazer filler tubes are 1 3/8 OD. It is a '71. I bought some 1 1/4 hose thinking everything was that size. Any suggestions on how to go from the stock 1 3/8 filler to the 1 1/4 tank? Thanks
67 C20/
68 C10 stepside/inline 250--current project
71 GMC 4x4
70 Blazer project-Zombie assault vehicle
67 4x4 Burb
dave666693 is offline   Reply With Quote
Old 04-05-2012, 07:20 PM   #2
Firebirdjones
Re: Poly tank hose size?
I run the same poly tank with the smaller neck. I simply used the fuel flex hose from Napa (1 3/8" as you describe) and double clamped it to the smaller fuel tank neck.
It's only 1/8" difference which equates to 1/16" for the circumfrance. That's not enough to worry about, even a single worm clamp would do the job. I double worm clamped mine just because I could. Been like that for years, never leaks a drop and I fill it all the way up the neck at the station. No worries.
Firebirdjones is offline   Reply With Quote
Old 04-05-2012, 09:30 PM   #3
SeventyOne
Good info Firebird.
I would also think that an exhaust shop out to make a "conversion" piece like a 1-3/8" to 1-1/4" reducer out of metal. So the setup would be: gas inlet - small piece of 1-3/8" tubing - reducer - small piece of 1-1/4" tubing - poly tank inlet.
SeventyOne is offline   Reply With Quote
Old 04-06-2012, 09:28 AM   #4
Burt4x4
Burt4x4's Avatar
I ran a poly tank for a while. When I installed it I cut off the long filler neck from the factory tank. Then cut the rubber filler hose in 1/2, hoseclamped in the metal piece with rubber at both ends to merry it all togeather
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 04-06-2012, 09:55 PM   #5
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
I used a piece of exhaust tubing to make a bushing.
low'n slow is offline   Reply With Quote
