Old 04-05-2012, 05:32 PM   #1
cst 72 blazer
cst 72 blazer's Avatar
rear pinion angle 4" lift blocks?
ok i have an 89 and a 90 both with blocks in the rear.i had a growl in the rear of the 90 once i added 3/4 axles.to solve problem i droped the t-case cross member 1 inch with those spacers that came on the blazers..the 89 is a half ton and made a slight growl runnin round 55mph so i tryed the cross member drop and it cured the problem in foward but now makes a very odd sound in reverse? any good ideas?
Chris Heinz
cst 72 blazer is offline   Reply With Quote
Old 04-05-2012, 07:36 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: rear pinion angle 4" lift blocks?
Most all the lift blocks I've seen have the angle correction milled into their manufacture to compensate for the lift. Are your lift blocks tapered?
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-05-2012, 08:30 PM   #3
cst 72 blazer
yes they are taperd,as you say it helps the pinion angle on the rear but the one i was suspecting is the one at the Tcase.note i was holding the brake and rocking it and found a ripped trans mount on the cross member lol feel like an idiot now.hopeing that will fix it we shall see tom.thanks for the reply
Chris Heinz
Old 04-05-2012, 09:03 PM   #4
68Timber
68Timber's Avatar
Good deal, glad you found it.
John
74 Honda Z50 build
