Old 04-05-2012, 09:09 PM   #1
Rogue_Alphonse
Rogue_Alphonse's Avatar
I have a pretty bad oil leak...
SOMEWHERE at the top of the back of the block, and it's a nice steady drip... it has the trans, starter, and everything else under the truck covered in oil, even has a baked on black spot on the long tube header, just on the passenger side. I replaced the intake gaskets twice, once with and once without the rubber inserts for the middle. Distributor is clean. It's our basic TBI 5.7 from 1990, .202 heads if that makes any difference. HALP!
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc.
1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980.
1998 Jeep Grand Cherokee 4.0 fully loaded daily driver!
Where there's a will, there's a rig!
Rogue_Alphonse is offline   Reply With Quote
Old 04-05-2012, 09:14 PM   #2
76stepsidechevy
Re: I have a pretty bad oil leak...
oil pressure sending unit or line for a gauge?
76stepsidechevy is offline   Reply With Quote
Old 04-05-2012, 09:31 PM   #3
Rogue_Alphonse
The sending unit is down on the driver's side of the block, and where the other style unit would go on top is totally dry
Old 04-05-2012, 09:35 PM   #4
76stepsidechevy
Im trying to think of where else it could come from back there. Is the oil pooling around the intake bolts?
Old 04-05-2012, 09:57 PM   #5
INSIDIOUS '86
INSIDIOUS '86's Avatar
You have to have the middle seals. The plug at the back may be leaking as well as the distributor seal. Otherwise your valve cover gaskets are shot
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-05-2012, 10:07 PM   #6
Rogue_Alphonse
I had a guy at a race shop tell me if the rubber seal is blown, don't use it. Also when I got the new intake gasket kit yesterday and put it on, all it came with was the ones for between the intake and head, and a little tube of black silicone for the front and back. Distributor got a new gasket as well, because it was also in the kit. from what I can feel, it's the intake AGAIN but then again the oil could just be running along the seem where the intake meets the block. Oh yeah and the valve cover gaskets are the best I've ever seen for being re-used once!
Is it possible that the intake could be cracked where the distributor goes through? Only thing is, like I said, intake is dry, block is wet.
Old 04-05-2012, 10:10 PM   #7
Rogue_Alphonse
No, it's basically running down the bell housing and starter wires and thanks to driving it's all over everything else behind the bell housing. FLywheel is dry [havent put the clutch dust cover back on yet]
Old 04-05-2012, 10:22 PM   #8
92GMCDriver
92GMCDriver's Avatar
I had the same problem with my tbi it leaked all over the trans and down onto the starter it turned out to be the distributor seal. i know it might not look like it at first because mine sure didnt until i took it out to get a closer look.
Cole.
1967 GMC c15
1991 k2500
2005 2500hd Duramax
92GMCDriver is offline   Reply With Quote
Old 04-05-2012, 10:30 PM   #9
jhngardner367
jhngardner367's Avatar
I agree.It's either the distributor gasket,or the neoprene seal between manifold/block has slipped.I don't use them,anymore.I just use Hi-temp silicone,and clean/dry the surfaces.
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
Old 04-05-2012, 10:47 PM   #10
bilfman
bilfman's Avatar
Valve covers are usually the culprit here. Make sure you bang your covers straight, another good upgrade is get some extended tabs for the covers it spreads the bolt tension farther out on the cover. These are a little wing shaped steel tab that you put your existing bolt through. Seeing as you have done the intake I would make sure your valve covers are straight and tab them up.
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 04-05-2012, 11:11 PM   #11
Rogue_Alphonse
TBI, bolts are in the center and I have thick as hell rubber gaskets. No evidence of leakage at all from either one.
Old 04-05-2012, 11:11 PM   #12
Rogue_Alphonse
Yeah I went your route the second time and still, same issue.
Old 04-06-2012, 09:57 PM   #13
grs
My 87 with a 305, and TBI leaked like yours is leaking. It was the intake. I paid a shop to replace it, because I did not feel like doing it. You said you replaced yours. Maybe you did it wrong. Clean it real good then drive it, and put it on a host and shine a light up the back of the engine, and maybe you will see where it is leaking from. Let us know what you find out.
grs is offline   Reply With Quote
