Old 04-01-2012, 09:43 AM   #626
Kim57
Kim57's Avatar
Re: Lurker OrrieG Progress Pics
Very cool.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 04-01-2012, 12:05 PM   #627
_Ogre
_Ogre's Avatar
nice work on making it fit the updated column
shop air compressor timer
Old 04-01-2012, 03:57 PM   #628
OrrieG
OrrieG's Avatar
Bling! Cleaned and polished the cap. 400 wet dry, black cutting compount, red rouge polishing. Still need to hit it with the magic blue stuff, but misplaced it!
Old 04-01-2012, 07:10 PM   #629
Kim57
Kim57's Avatar
Cleaned up real nice.
Kim
My build thread
Old 04-01-2012, 08:50 PM   #630
OrrieG
OrrieG's Avatar
Yeah, not 100 point finish but I don't mind using 50-60 year old parts if they look reasonable. New repops are $65.00. I have a little over an hour in this one.
Old 04-06-2012, 12:56 AM   #631
OrrieG
OrrieG's Avatar
Steering wheel trial fit in the truck and check for belly clearance. Looks ok.
Old 04-06-2012, 12:58 AM   #632
Daze57
Daze57's Avatar
looks v v nice !
Daze57 is offline   Reply With Quote
Old 04-06-2012, 10:39 AM   #633
Kim57
Kim57's Avatar
Sweet.
Kim
My build thread
Old 04-06-2012, 05:52 PM   #634
sgtusmc
sgtusmc's Avatar
Cap came out looking really nice.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 04-06-2012, 07:36 PM   #635
Rude Dude
Rude Dude's Avatar
Looks good, a big wheel excellent choice for the 4X!
Rude Dude is offline   Reply With Quote
Old 04-06-2012, 07:44 PM   #636
OrrieG
OrrieG's Avatar
Thanks guys, rude you are right its a TRUCK wheel not one of those fufu ones! I've never driven this with power steering, will probably have a little bit of learning curve on over correcting.
Old 04-07-2012, 11:19 AM   #637
Madd Doc
Madd Doc's Avatar
Nice job on the wheel, I would rather spend 2 hours making something I could buy for 2 dollars.
Madd Doc is offline   Reply With Quote
Old 04-22-2012, 08:26 PM   #638
OrrieG
OrrieG's Avatar
Here are some photos of the steering wheel mods I had to make. I am going to do a separate detail thread just in case anyone else wants to do it. The method should work for an later model GM standard, tilt or tilt/tele column. I had to add a washer on the back of the 48 wheel to take the place of the stock upper bearing that the wire to the horn relay attaches to. I had to modify the GM trim pieces.
Most interesting part was figuring out the transition between the trim ring and steering wheel. I thought about using fiberglass but decided to take a trip to the big box hardware store to see if I could find something with an angle to transition from the trim to the wheel. I was wandering around looking a one of the female associates asked what I was looking for. I told her what I was trying to do, she thought for literally about 5 seconds then said follow me. Not a hard thing to do, she was easy on the eyes. We ended up in the toilet repair section. She grabbed a tank to base gasket and asked if it would work. With a little trimming it looked plausible. I asked her how she figured that out, she said her and her husband are gear heads too and are always doing the same thing, looking for something that works.
Old 04-22-2012, 08:28 PM   #639
OrrieG
OrrieG's Avatar
Also started the wheel repair with my trusty roto tool and JB Weld.
Old 04-22-2012, 08:42 PM   #640
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Looks good, I like all the DIY stuff you do!
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 04-22-2012, 09:36 PM   #641
oldman3
oldman3's Avatar
Nice mod and repair.....Jim
oldman3 is offline   Reply With Quote
Old 04-22-2012, 11:27 PM   #642
Kim57
Kim57's Avatar
Nice job.
Kim
My build thread
Old 04-23-2012, 09:37 AM   #643
edge
edge's Avatar
I sure do enjoy this thread.
edge is offline   Reply With Quote
Old 04-23-2012, 12:20 PM   #644
Daze57
Daze57's Avatar
lookin good OrrieG
Old 05-07-2012, 12:50 AM   #645
OrrieG
OrrieG's Avatar
Had a good weekend, banging and sanding tailgate, bumpers, grille, and other front clip parts. Also worked on steering wheel, third coating of filler. Glad that the hood only had some small dents where it was slammed to hard.
Old 06-03-2012, 11:29 PM   #646
OrrieG
OrrieG's Avatar
Here are a couple of progress pics. Basically sand, Rage, sand again. Using JB weld on the steering wheel, from what I read over at the HAMB board the epoxy metal holds up better than plastic fillers. Hood is ready for final primer and blocking. Tailgate and bumpers will be too. Steering wheel is ready for prime and paint, took probably 6 hours total to grind, fill, sand, fill, sand, fill, sand... Does not look like much work but every spoke was cracked on both ends plus the guy had a necker knob that cracked and dented the rim. And a dozen or so cracks around the rim. I did not grind them, just filled, I will use a leather wheel cover so it is not as critical. Looks like next weekend is going to be a paint one. Also had a little cash windfall so getting parts critical to moving forward (AC fittings, gas filler, door glass, bed bolt kit, etc.) Comes from stuff my dad had I put on ebay. Turns out original 55-59 VW tail light assemblies are like our GMC front parking lenses, not reproduced and rare. Also found a box of 4 NOS Fram canister filters like on the 216 and 235 engines. I put one on ebay and was amazed it sold for $123.
Old 06-03-2012, 11:37 PM   #647
oldman3
oldman3's Avatar
Everything coming together, looks good....Jim
Old 06-04-2012, 08:34 AM   #648
Kim57
Kim57's Avatar
Looking good OrrieG.
Kim
My build thread
Old 06-18-2012, 12:51 AM   #649
OrrieG
OrrieG's Avatar
Modified the tailgate trunions. When I was working on the tailgate cables and latch I noticed that I could get the tailgate to line up, but when I opened and reclosed it, it dropped about 3/16". I looked closely and discovered my trunions were not perpendicular to the rear sill and tailgate. The trunions were not bent or tweaked, the bed corners they mount to are splayed out a little bit. I do not know if it came from the factory like this or if they were bowed when the lift gate was installed. Anyway, I welded and ground on one side of the trunions to square them up. Next weekend I will refit the gate and see if i solved the problem. I also found the part the trunion goes into was out of round and enlarged, so I tuned it up for a tighter fit with the 2# adjustment tool. Also did more body work, wax on wax off drill with Rage but getting close.
Old 06-18-2012, 11:09 PM   #650
daverod
SSN 706
daverod's Avatar
What did we do before Ebay. Nice sell.
daverod is offline   Reply With Quote
