Old 04-06-2012, 09:02 PM   #1
Rob68c10
Need brake help ASAP
My truck is currently on jack stands because I apparently didn't do enough research. I have a 68 that I converted from manual drum to power disc up front. The rubber lines would not connect to the metal lines, and my proportioning valve lines would not connect. I ordered pre bent lines from LMC for a 1972, and they are no where near close at all. Did I get bad parts or is there something that I am missing here? I need to know as soon as possible so I can get this thing out of my buddies garage.
Rob68c10 is offline   Reply With Quote
Old 04-06-2012, 09:08 PM   #2
fatgump
fatgump's Avatar
Re: Need brake help ASAP
The same thing happened to me. I ordered the non power brake kit by accident.
fatgump is offline   Reply With Quote
Old 04-06-2012, 09:08 PM   #3
71swb4x4
71swb4x4's Avatar
According to this thread: http://67-72chevytrucks.com/vboard/s...d.php?t=456889 you need a conversion brake hose.
I think you need a disc/drum proportioning valve too, have you installed that?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 04-06-2012, 09:10 PM   #4
Rob68c10
I have the disc/drum prop valve off a 72 that had power brakes.
Old 04-06-2012, 09:20 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
The 71-72 disc brake steel line kits are bent totally different from the 67-70 drum brake trucks.
The 71-72 steel lines are routed to the front side of the crossmember,... where the 67-70 drum brake steel lines exit on the back side of the crossmember.
You have 2 choices.
1) install the 71-72 lines and add a tab on the front side of the crossmember.
These tabs can be welded or bolted on.
All you need is a designated spot to connect the steel line to the rubber brake hose.
2) You can also run 67-70 drum brake steel lines, with conversion hoses connected at the stock location. (behind the crossmember)
Either way,... you will need to bend up a set of new steel lines to connect to the master cylinder.
Or buy a COMPLETE 71-72 steel line kit that goes all the way to the M/C.
You will need a disc brake M/C and Prop valve.
Keith
Convert to disc brakes.
Old 04-07-2012, 01:22 PM   #6
treveiger
treveiger's Avatar
Hey please keep us updated!
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
