Old 04-07-2012, 01:00 AM   #1
74sqrbdy
74sqrbdy's Avatar
Mid Length Headers
Does anyone know of any mid length headers that will fit my 74 stepside with a 350? The Headman long tube headers that are on it are dented up from dragging on my lowered truck. I would rather use mid length than block hugging shortys. I read somewhere on here the camaro headers would work??? Thanks.
74sqrbdy is offline   Reply With Quote
Old 04-07-2012, 01:25 AM   #2
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Mid Length Headers
These fit on my 73.
http://m.summitracing.com/parts/PTE-H8021-1
Have these on it now do not hang below the frame.
http://m.summitracing.com/parts/DOU-D310
Old 04-07-2012, 11:22 AM   #3
SCOTI
SCOTI's Avatar
2nd Gen Camaro or Chevelle 3/4 length headers work on these trucks.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-08-2012, 12:07 AM   #4
74sqrbdy
74sqrbdy's Avatar
Thanks KQQL IT and SCOTI, I will check those out. I have had the 3 bolt flange collector type and have had problems with the gaskets blowing out. I thought the ball type flange would seal better.
Old 04-08-2012, 01:55 AM   #5
SCOTI
SCOTI's Avatar
The 'trick' I've found that works is the flanges need to be thicker. I use 3/8 thick material & build my own where possible as it's usually cheaper this route unless buying a new set of headers.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
