Old 04-08-2012, 10:25 PM   #1
sprinter11r
sprinter11r's Avatar
64 weekend cruiser
Hello all. When I was 14 years old, I bought my first truck, a 66 chevy SWB stepside. Drove it all over Missouri and northern arkansas till I was out of college. Got involved in sprint car racing with my brother which took all my time and money untill recently when I finally sold all my racing equipment. I decided we needed something to work on and have some fun with so I started looking for an old truck. I was originally looking for a swb but found this LWB C20. The body was in such good shape for this area I decided I better jump on it. There is a small amount of rust on the bottom of the front fenders, and the right kick panel on the inside. There are only two small dents on the entire body plus the tailgate looks like someone modified it with a hammer for some reason.
sprinter11r is offline   Reply With Quote
Old 04-08-2012, 10:33 PM   #2
sprinter11r
Re: 64 weekend cruiser
I have been working on it a couple weeks already. Im switching it to 1/2 ton with a cross member and rear end from a 68. the rear is a 3:73 posi 12 bolt. Im going to start with 2 1/2 inch drop spindles a 4 inch drop springs in the rear and see how that looks. also will have PS and PB. Just want something that looks good and fun to cruise around in on the weekends.
Old 04-08-2012, 10:57 PM   #3
Captainfab
60-66 Nut
Welcome to the forum
You don't mess around do you? Down to the frame already.
Nice score on the 12 bolt posi.
Did the truck come with a 327 and TH400?
Old 04-09-2012, 08:32 PM   #4
c.brown
c.brown's Avatar
nice solid truck to start with and with air
1966 suburban slammed fuel injected 6.2L
My build
c.brown is offline   Reply With Quote
Old 04-09-2012, 10:29 PM   #5
sprinter11r
yes 327 with TH400, but I pulled a head off the engine this evening and it probably needs complete overhaul. I have a decent running 350 so I need to decide what im going to do there.
Old 04-16-2012, 09:38 PM   #6
sprinter11r
I have made some progress this week. We replaced the C20 rear cab mount with C10 style and built a new perch.
Old 04-16-2012, 09:45 PM   #7
sprinter11r
I got the frame painted and it came out pretty good. Since I plan on driving this truck I didnt go to the expense of blasting and powder coat. I degreased it and power washed it along with a little wire brushing and scuff padding. then I used a satin black equipment enamel. I have used equipment enamel quite a bit in the past. It covers good and sticks to about anything. $28 a gallon.
Old 04-16-2012, 09:54 PM   #8
sprinter11r
The rear end is in. new brake shoes, wheel cylinders, park brake cables, drums, 5 hole axles, truck arm bushings, and 4 inch lowering springs. Panhard should be here tommorow.
Old 04-18-2012, 09:59 AM   #9
1963c-10
1963c-10's Avatar
Great optioned truck. Keep up the hard work, its looking good.
1964 Short bed trailer
Old 04-21-2012, 03:44 PM   #10
juanz1947
rusty 66
juanz1947's Avatar
Nice truck I like the color
1947 chevy fleetmaster
http://www.cbforum.net/forum/
1966 chevy c10 long bed
http://67-72chevytrucks.com/vboard/s...d.php?t=439219
1970 chevy impala custom
http://www.layitlow.com/forums/index...pic=349867&hl=
juanz1947 is offline   Reply With Quote
Old 04-22-2012, 12:50 AM   #11
sprinter11r
]More progress this week. I got the front end back together. All new ball joints,control arm bushings, tie rods, idler, drop spindles, disc brakes, and power steering.
Name:  64 chevy 052.jpg
Just like christmas!
Old 04-22-2012, 12:56 AM   #12
sprinter11r
I also got a set of ralley wheels with "good for now" tiresName:  64 chevy 053.jpg
Still need to run brake lines, but I think Im about done with the chassis for now. Time to start on the cab.[ATTACH]Name:  64 chevy 031.jpg
Size:  51.1 KB[/ATTACH]
Old 04-22-2012, 01:37 AM   #13
Vics63Chevy
Vics63Chevy's Avatar
Feels great receiving those packages don't it? hahah great progress keep those pics coming..
1963 Destiny Build Log
Vics63Chevy is offline   Reply With Quote
Old 04-28-2012, 09:23 PM   #14
sprinter11r
started sanding today. also hit the floor board and rockers with the sandblaster. they are pretty solid, but did have some small holes blow thru. will have to cut some areas out and replace, but in really good shape compared to some I have seen.
Old 04-28-2012, 09:25 PM   #15
sprinter11r
The red dots are what needs filled. This firewall looks like swiss cheese.
Old 05-10-2012, 10:35 PM   #16
sprinter11r
Getting some done on the cab. Racing season has started so working on the truck has slowed a little. hopefully I will have the cab about ready for paint this weekend. I should have everything for my motor next week, so I can get that back together.
Old 05-11-2012, 09:55 PM   #17
65 old school
65 old school's Avatar
Nice find!. You have a great start. Keep up the great work!... I wish I had to slow down on my build so I could go racing!..
65 old school is offline   Reply With Quote
Old 05-12-2012, 12:22 AM   #18
markeb01
Senior Enthusiast
markeb01's Avatar
First time I’ve seen your build thread. Great progress on a very clean original truck. Looking forward to more updates.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 06-12-2012, 11:19 PM   #19
sprinter11r
making some more progress. got the cab painted and the motor is back together.
since the PO chopped the dash up for their 8 track tape player, I just cut the whole center. then put in a flat piece and cut it for the new a/c vents and control as well as stereo.
Old 06-13-2012, 06:50 PM   #20
SBTork
Garage wrench
SBTork's Avatar
good progress, great looking motor!
-Adam
90 V1500 GMC Suburban 350/700R4/NP241.....
01 Saturn SL1 stock DD.....
SBTork is offline   Reply With Quote
Old 06-14-2012, 11:09 AM   #21
jchav62
1962 C-10
jchav62's Avatar
Nice work... You don't mess around! Everything is looking wicked.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 06-14-2012, 10:33 PM   #22
sprinter11r
got the motor transmission and driveshaft in and set the cab back on tonight. its starting to look like something again.
Old 06-15-2012, 06:32 PM   #23
McMurphy
McMurphy's Avatar
I really like the look... Black and Red are a really smooth combo!
Michael McMurphy
My 66 Stepside
My 64 Tow Truck
My 66 Tempest
Table Of Contents Added to Page1
McMurphy is offline   Reply With Quote
Old 06-23-2012, 03:36 PM   #24
sprinter11r
Today I got the fatmat in. Going with American Auto Wire classic update harness. looking forward to start getting things back together.
Old 07-26-2012, 05:12 PM   #25
sprinter11r
progress has slowed with the heat. I have managed to get the glass back in and about have the interior and engine wiring done. I am taking the seat to the upholstery shop tomorrow. here are a few more pics.
