Old 04-09-2012, 05:27 PM   #1
JumboAMONGus
JumboAMONGus's Avatar
71 c10 drop , wheel sticks out ?
after doing 3inch spindle 2 inch spring new tie rods bal joints , now lowering it i just noticed my drivers side wheel sits out almost 1 1/2" and yes there the same rims i checked ? i did notic that thereis only 3 shims on upper arm joints and like 7 or so on the drivers side but not sure that would make it that far out ? any help would be awsome ,,
JumboAMONGus is offline   Reply With Quote
Old 04-09-2012, 05:35 PM   #2
JumboAMONGus
Re: 71 c10 drop , wheel sticks out ?
[/IMG]
Old 04-09-2012, 05:36 PM   #3
JumboAMONGus
passenger side[/IMG]
Old 04-10-2012, 11:50 AM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Yes, different number of shims could cause that.
One test you can do is to park on a flat paved surface. Use a large carpenters square and see if your wheels are square to the pavement. Because of the tire bulge at the bottom (with the weight of the vehicle) you might want to measure from the rim lip, top and bottom. If they are even, then it's square to the ground. It's hard to tell but it looks like the pass side one has some negative camber compared to the driver side.
Hope that helps.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 04-10-2012, 12:11 PM   #5
JumboAMONGus
yes i will try this after work and i noticed the angle of the camber ,,, im also gonna make sure te bod is all mounted never know from previous owner ,,new body mounts on way in mail but thats alot ,,,
