#101 |
Re: '66 GMC BBW w/351E and Factory Buckets
I just put gas in it. I was hoping I didnt have to line it at that point but my tank was pretty dang bad.
1966 GMC Extended cab 1 1/4 ton 4x4 My build thread 1958 Chevy 1 ton dually flatbed My Dad's build thread 1966 GMC Custom Trim Big Back Window W/351e My Time-Killing Project Truck 1966 (Not So) All Original Chevy Custom Trim Suburban My Dad's Time-Killing Project Truck |
#102 |
its holding up on ya? no more rusting has ocured?
#103 |
![]() Join Date: Jun 2010
After the initial muratic acid cleaning (and rinsing/drying), we put gas in and still had rust issues...no coating yet.
We then elected for the Hirsch kit and recleaned and coated the tank and are still on the first tank since then with no probs...so far. The new 10 bolt rearend is narrow at 61" WMS to WMS, but having 0 miles on it makes up for it's "short" comings... ![]() New spring pads, u-bolts, plates, and u-joints for the old driveshaft and the rearend was a bolt-in job...even the old brakelines fit with no modifications. ![]() We did pull the bottom three leaves out of the stock 9 leaf pack, dropped it a bit and seems to ride nice...we're considering cutting a portion of a coil off the front too.
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
#104 |
Few more pics of before and after spacers...
#105 |
thanks for the info i need to do this with mine
#106 |
60-66 Nut
So does that Colorado rear end have the 6 x 5.5 wheel bolt pattern?
#107 |
If you have any questions when you do it feel free to ask bud!
Yes it does, a lot the guys told me that you can physically see the difference in size of bolt pattern between a full sized rear and the colorado rear. But i felt like being stubborn and trying one of my wheels onto to it, and sure enough it fit perfectly, it also fit the full sized rear.
#108 | |
60-66 Nut
Cool! Thanks for verifying that. Do you have any other info on that rear end such as ring gear size, axle splines, etc?
#109 |
Registered Loser
Very cool! I had the Holley on my V6 and it ran great.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
#110 | |
![]() Yea, that and the HEI really woke it up, the 3.42s have it spinning pretty good around 70, but it'll still jump out for passing...we're going to drop a little tach on it for monitoring though. We dropped it off a local upholstery shop for new padding and carpet before adding new pedals, door sills, and kick panel covers. ![]() Few pics of where its at now...
#111 |
i want to hear it. the exhaust looks nice. i ended doin mine the same way only i cut angles since i dont have a bender. i had flowmasters and switched to glasspacks. i like those better. but it sounded nice with the flowmasters at idle. i have a 305 v6 tho. you guys are doing great. i guess it helps to have some help. keep it up.
#112 |
Nice truck...do you have any updates on it? I think it is great that you saved it and are making it nice again.
C@rnut001 (Owen) Alaskan Members Check In http://67-72chevytrucks.com/vboard/s...22#post5094422 http://67-72chevytrucks.com/vboard/s...18#post6778618 |
#113 |
Resident of Here
Subscribed! Love it!
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#114 |
Whats the status on the new seat covers?
#115 |
We had parked this for a bit because of heavy leaks from the power steering valve, hoses, and ram.
We investigated options for both replacing those components and rebuilding them before deciding to go the less expensive route of rebuilding them. My son chased down rebuild kits for both the valve and ram for just a few bucks...not many parts involved. We had all new hoses built and then disassembled, cleaned, and rebuilt the valve and cylinder. We reinstalled everything this past weekend and put a few miles cruising around town...perfect steering and NO leaks ![]() ![]() BTW - Haven't done anything with the seats...yet.
#116 |
Well, I was going to get some pinstriping done on the truck for my birthday, but as I was driving her to the car wash, she died. After losing power and feeling really sluggish I let off of the gas and it just quietly died while cruising at about 50. I coast to a stop and try to start it, nothing. I figured the alternator had finally given up so we tow her home, replace the alt. with a spare one we had, charged it up, and tried it again. Nothing. The starter was trying but the motor wouldn't turn. So I tried to turn the crank with a ratchet and a 18" cheater... It won't budge at all!! So the truck is back in the back yard with a frozen motor until we can look into what's going on...
![]() ![]() ![]() ![]() ![]() Posted via Mobile Device
1966 GMC Extended cab 1 1/4 ton 4x4 My build thread 1958 Chevy 1 ton dually flatbed My Dad's build thread 1966 GMC Custom Trim Big Back Window W/351e My Time-Killing Project Truck 1966 (Not So) All Original Chevy Custom Trim Suburban My Dad's Time-Killing Project Truck Last edited by oklahomaduner; 04-08-2012 at 11:50 PM. |
#117 |
Junk Yartist
C'mon man! 351's are everywhere! Just go down to your local autoparts store and pick up a long block! I'm sure they have one sitting on the shelf in the back of the store.
-Jeremy YOU ONLY FAIL IF YOU STOP TRYING 70 Crew Cab Build Link 70 GMC Suburban 4X4 build thread 95 Yukon Daily Driver Rebuilding an NP205 |
#118 |
![]() Join Date: Nov 2007
Hate to here this!
Tim |
#119 |
![]() ![]() Join Date: Jul 2002
Hopefully it is something not too major and you can get it back going again without too much expense.
#120 |
Just here to tinker
![]() Join Date: Jun 2008
Sorry to hear about the motor freezing up.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/showthread.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 73 Chevy C20(Daily)http://67-72chevytrucks.com/vboard/s...d.php?t=852767 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(sold) |
#121 | |
The 60-66 GMC/Pontiac guy....
Just way too many GMC's with SBC's in them.. (IMHO) Of course it's your ride to do as you wish. The guys on the V6 website normally will do pretty much anything they can to help you keep it a V6. I know I regret getting rid of my original V6. ![]()
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() |
#122 |
BLAZER THIRTY!!
![]() Join Date: May 2007
cool build! love them old GMC'S!
49 chevy 5 window 20 year project (sold)😟 57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.) 62 GMC 305 V6 custom L/B 72 HIGHLANDER K5 BLAZER 2nd owner ![]() ![]() ![]() 71 K5 MAMMA'S RIDE! 63 GMC 4X4 305 V6 62 GMC SHORT BED SERVICE BODY V6 (STUMPY) 74 GMC CUSTOM 1500 L/B |
#123 |
![]() Join Date: Sep 2011
Hey guys, we need some updates here too. We need to know more about that motor problem.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
#124 |
I missed this thread earlier, till it returned to the top. Just a passing note, my first pickup (bought in 1972) was a '67 Chevy "CST", had the same bucket seats, I think the vinyl was a bit different....but I might be just thinking that 'cause they were red. 40 years fades (some) memories! I knew at the time they were extremly rare, I only knew of one other truck that had 'em. I have NEVER seen a 60 -66 with those!
#125 |
I guess I must have unsubscribed from my thread..
