Old 04-10-2012, 02:36 PM   #1
meteshjj
Tougher Suspension
So, I see here that most people want to bag and drop these trucks. Personally, I think that takes away the "truck" part. What I would like to do is find a way to lift the truck on both ends by about 3 inches. Does anyone know of a good place to find a lift kit for these trucks? Mine is a 1963 GMC 1500 LWB with a utility box,, so it sits kind of low. The rear suspension is leaf and the front is torsion (I think).
My Fleet:
1963 GMC 1000, 205 V6, 4-speed standard, 7'6" utility box, 100% Original
1969 Ford Bronco, 302 V8, 3-speed standard, 12" lift kit [SOLD]
1952 Ford F1, 239 Flahead 8, 3-on-the-tree, 100% original, fully restored
1993 Dodge Ram 250, 360 Cummins, 5-speed standard, stock (for now)
meteshjj is offline   Reply With Quote
Old 04-10-2012, 03:33 PM   #2
sixty4c10
Re: Tougher Suspension
If it has torsions in front, you can adjust them up like I did on my Nissan truck. Rear leaf? Put some blocks back there... That should be about all you need to do. Put some fresh shocks in if you haven't already.
sixty4c10 is offline   Reply With Quote
Old 04-10-2012, 03:42 PM   #3
1963c-10
1963c-10's Avatar
63 wont be torsion bars, would be coil springs in the front.
1964 Short bed trailer
Old 04-10-2012, 04:10 PM   #4
sixty4c10
Your springs and shocks might just be worn out and sagging from the added weight of the utility box. New shocks in my buddy's toyota pickup actually lifted it about an inch and really tightened up the handling.
Old 04-10-2012, 04:44 PM   #5
jimmydean
jimmydean's Avatar
Take a look at Dino's pre-runner build, that truck is a beast! Sits on bags and looks as tall as my Toyota 4x4.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 04-10-2012, 11:17 PM   #6
longbed67
longbed67's Avatar
An 06 4x4 2500 duramax bed height is at 35" off the ground stock (just as reference). With d2600 bags you can achieve that same height easily in the 67-72's and drop it to set the frame right on the axle and makes it easy to hook up to a trailer- (in the rear). In the front you can drop the crossmember to the ground all the way to almost 3" of lift in the front with bags on a 2wd.
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 04-13-2012, 12:41 PM   #7
Jay W
Jay W's Avatar
plus with air you can lower it some during long drives and gain some mpg back, depending on tire size.
69 c10 lwb
Jay W is offline   Reply With Quote
lift, suspension
