Old 04-12-2012, 10:29 AM   #1
madcow75
madcow75's Avatar
looking for A/C cab tech info/ cowl area
Okay I have a 1976 non a/c cab which I am converting to a/c. And I have 2 questions.
-Are the holes in the cab where the kick panels located, (outside air flap diverters) are they there on an a/c cab. Or could I weld them up. I was looking at the LMC catalog and the drivers side kick panel appears to be solid.
-The cowl area on the cab where the screen is. Can I smooth that out and weld it solid. Or are they required for heater/a/c operation. I do understand they are there to access the wiper arms, but I would deal with that if I had a problem. My biggest thing is leaves and debris getting in there and rotting out the cowl area of the cab.
I just got done welding up the swiss cheese type cab area next is por-15 the snott out of it. I don't ever want to see it again.lol
madcow75 is offline   Reply With Quote
Old 04-12-2012, 11:01 AM   #2
J Knight
J Knight's Avatar
Re: looking for A/C cab tech info/ cowl area
Not sure if this helps or not but my 82 is a factory a/c truck, inside the cab there is no flap/door on the drivers side. There is one on the passenger side, it is vacuum controlled and the manual pull lever delete.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 04-12-2012, 11:29 AM   #3
madcow75
madcow75's Avatar
Correct thats what I thought. Is there large hole behind the passenger side kick panel in the cab. And is the hole there in the cab on the drivers side or is it solid?
Old 04-12-2012, 11:52 AM   #4
hartbraker
It's solid on the drivers side on my 86 and it has factory air... they only hole is for the power windows....
1986 Chevy Silverado k30: factory air, tilt wheel, 454cu 7.4L, Turbo 400, NP205, Corporate 14 bolt, Dana 60 front, 4.10 gears, SRW, long bed, standard cab... MY TRUE LOVE
hartbraker is offline   Reply With Quote
Old 04-12-2012, 11:55 AM   #5
madcow75
madcow75's Avatar
Okay then the drivers side is going to be welded shut then. I will leave passenger side open.
How about the cowl area? Any thought
Old 04-12-2012, 12:04 PM   #6
hartbraker
In all honesty, I wouldn't weld the cowl area shut because then you have to worry about water collecting and/or lack of air movement depending on what you're talking about welding shut. If you're planning on using POR15, that stuff is crazy good about preventing rust and it sounds like you're meticulous enough to clean out any leaves that do end up down in the cowl. I'd leave that part alone if I were you, but that's just my opinion...
Old 04-12-2012, 12:15 PM   #7
v30crewcab
v30crewcab's Avatar
when I converted mine to a/c I left the stuff on the driver side. its nice sometimes to open it and have cool air blowing there instead of running the a/c.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 04-12-2012, 12:37 PM   #8
madcow75
madcow75's Avatar
Yes that actually does sound good leaving it actually now that you say that. about leaving the drivers side kick panel open.
Old 04-12-2012, 06:40 PM   #9
madcow75
madcow75's Avatar
What about the cowl area has anyone closed it in to keep debris out
