Old 04-12-2012, 09:55 PM   #1
bfink
smooth firewall
i was going to get some work done on my 55 this weekend and one of the projects i need to tackle is filling the tons of holes in the firewall , i was thinking about just making an 18g or so plate and welding it on to the firewall . anybody do this ? pics ?
bfink is offline   Reply With Quote
Old 04-13-2012, 12:38 AM   #2
OrrieG
OrrieG's Avatar
Re: smooth firewall
Do a search, we talk about this about every two weeks. Back up small holes with a strip of copper and weld them shut. I cut patchs out of 18 GA like you said and just spotted it in moving in a circular pattern. Keep cold water and a rag handy to reduce warpage. I had about 50 holes from 1/8" to 2" and it took me 8 hours to weld, 8 to grind and about 12 in body work.
Old 04-13-2012, 07:46 AM   #3
72Mountaineer
72Mountaineer's Avatar
Re: smooth firewall
Check out Custom Classic Trucks....tech....smoothing a firewall. Can't do a link, sorry.
72Mountaineer is offline   Reply With Quote
Old 04-13-2012, 12:01 PM   #4
hsdropout
Re: smooth firewall
I cut a couple pieces of sheet aluminum to fit the upper areas and riveted them on...... planned on putting an old school "engine turn" pattern on them.......but ended up priming them with the rest of the cab (impatient). Don't have a drill press to do the engine turning, I can always take them off and use them as patterns for custom pieces. The flat covers provide for a little more insulation space on upper firewall too.
It's not too cheesy for a DD.
All the holes below were welded up.
hsdropout is offline   Reply With Quote
Old 04-13-2012, 12:38 PM   #5
jimig1
jimig1's Avatar
Re: smooth firewall
I cut out and replaced some of it
55 2nd series Chevy Pickup
2019 Chevy Equinox(Daily driver)
2011 Chevy Malibu (Wife's car)
MSRA Member
I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose.
-George Carlin
jimig1 is offline   Reply With Quote
Old 04-13-2012, 01:50 PM   #6
bfink
Re: smooth firewall
thanks ! i was planning on welding up every hole like in Orrieg's pics but now im kinda leaning towards smoothing the whole thing out .
Old 04-13-2012, 03:57 PM   #7
Dan in Pasadena
Dan in Pasadena's Avatar
Re: smooth firewall
Me too because I kinda like the factory stamped ridges, BUT...I've also considered using something LIKE this:
http://www.nolimitparts.com/prodinfo.asp?number=CFWC
Seems like it would be SO much less work and for a non-"show" but nice driver I think it might be okay. Anyone have any experience with this or possibly a metal one (if someone makes such a thing)?
Dan in Pasadena is offline   Reply With Quote
Old 04-13-2012, 09:59 PM   #8
_Ogre
_Ogre's Avatar
Re: smooth firewall
I'm a fan of the factory ribs.
This cost me nothing except some welding wire.
$205 for a plastic firewall is a shame
shop air compressor timer
Old 04-13-2012, 10:57 PM   #9
bfink
Re: smooth firewall
i've seen those fiberglass covers too , but i dont know if anyone else with a camaro subframe has firewall clearence issues but i do ! i mean its not that bad but it close enough that i need all the room i can get . i made some thin cardboard templates today gonna see if i can get somebody to cut some out for me. Either way ( filling holes or welding covers on) im not very confident in my welding skills . I only have a little 110 wire feed welder and flux core wire but i guess practice makes perfect so we'll see.....
Old 04-13-2012, 11:01 PM   #10
bfink
Re: smooth firewall
Ogre.....it took a few minutes of looking at your firewall thinking "something looks different" but then i got it , you shaved the lip right ? how hard was that ?
Old 04-14-2012, 07:40 AM   #11
Russell Ashley
Russell Ashley's Avatar
Re: smooth firewall
"Seems like it would be SO much less work and for a non-"show" but nice driver"
For a driver, less work for me was welding up the holes that PO's had chiseled into the firewall and painting it and calling it good. I like the ridges and use the seam to support my wiring, so wouldn't want to remove it. My truck is definitely "non-show" BTW.
Russell Ashley is offline   Reply With Quote
Old 04-14-2012, 11:36 AM   #12
bfink
Re: smooth firewall
thanks ! i just picked that issue last night , thats exactly what i was talking about
Old 04-14-2012, 12:00 PM   #13
Dan in Pasadena
Re: smooth firewall
Originally Posted by Russell Ashley View Post
I like the ridges and use the seam to support my wiring...
Not sure I understand what you mean by this? Can you explain?
BTW, I'm not saying the plastic firewall cover is the be all/end all, just added it to this thread for future lookers. I intend to weld my holes shut, save the $200+ and feel good knowing "I did that".
Old 04-14-2012, 12:22 PM   #14
_Ogre
_Ogre's Avatar
Re: smooth firewall
my firewall was welded with a 110v flux core lincoln weldpak 100
yes practice makes perfect and the firewall is a good thing to practice on...
to cut out the seam? remove a couple of 6'' sections and start welding.
easy peasy...
Old 04-14-2012, 12:58 PM   #15
Russell Ashley
Re: smooth firewall
Dan, I'm more into function than looks with this truck. Not many people will ever see under the hood of my truck any way. I used self drilling screws and black cable mounting ties to hold that part of the harness up along the ridge. The green looped wire is for an under hood light that I will add eventually.
Old 04-14-2012, 01:41 PM   #16
bfink
Re: smooth firewall
[QUOTE=_Ogre;5313092]my firewall was welded with a 110v flux core lincoln weldpak 100
easy peasy...
[/QUOTE
yours looks great! i think im going to leave the seam as a paint break....gonna be black wrinkle paint below , body color above
Old 04-15-2012, 01:43 AM   #17
Dan in Pasadena
Re: smooth firewall
Looks clean, neat and organized....I wish mine did!
Old 04-15-2012, 11:26 AM   #18
Rude Dude
Rude Dude's Avatar
Re: smooth firewall
I used elevator bolts to fill a lot of the big holes, I did this to give me studs on inside to run wire retainers and future A/C attachment points, what ever I don't use I can hack the stud screws off.
Rude Dude is offline   Reply With Quote
Old 04-15-2012, 12:05 PM   #19
_Ogre
_Ogre's Avatar
Re: smooth firewall
my ramjet 350 has a 3/4'' harness just for the motor, i ran it thru the distributor hump
all my front wiring was run thru the grey flex conduit next to my ac lines
Old 04-15-2012, 01:11 PM   #20
1956chevtruck
1956chevtruck's Avatar
Re: smooth firewall
Here's what I did. Various stages along the way.
1956chevtruck is offline   Reply With Quote
Old 04-15-2012, 08:46 PM   #21
dsl30263
dsl30263's Avatar
Re: smooth firewall
Wow! Clean.
dsl30263 is offline   Reply With Quote
Old 04-15-2012, 09:13 PM   #22
48 GMC BURB
48 GMC BURB's Avatar
Re: smooth firewall
Sweet work. With the LT 1 do you need the recess or could you go totally smooth ? I am putting a 96 corvette drive train & suspension in a 51 AD pick up,
KC
48 GMC Burb
51 Chevy AD 3100/C 4 byShannon
74 Chevy P 10
48 Double Duty
04 SS Burb
01 Springer HD
48 GMC BURB is offline   Reply With Quote
Old 04-15-2012, 11:37 PM   #23
Rods57
Rods57's Avatar
Re: smooth firewall
Weld, prime, sand, prime, sand, prime, sand, prime....
Rods57 is offline   Reply With Quote
Old 04-15-2012, 11:49 PM   #24
1956chevtruck
Re: smooth firewall
KC
Could have probably gotten rid of the recess all together however, I like the old school like and feel!
Old 04-16-2012, 12:10 AM   #25
Dan in Pasadena
Re: smooth firewall
1956chevtruck - What's your color? Very, very nice.
