Old 04-13-2012, 01:23 PM   #1
61K10
61K10's Avatar
show pics of your 4x4 exhaust
show how you ran your exhaust-------thanks
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-04-2012, 03:35 PM   #2
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Re: show pics of your 4x4 exhaust
I would like to see this as well.
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 05-04-2012, 09:20 PM   #3
boz42
boz42's Avatar
'75 K5 3" duals into single 4". Pics aren't great but you'll get the idea.
This space for rent.
boz42 is offline   Reply With Quote
Old 05-04-2012, 09:48 PM   #4
woodwright
Enjoying left field
woodwright's Avatar
What specifically are you looking for? Some guys have duels, some have singles. What motor and tranny do you have? Mines a diesel. I'm running a single 4" to duel 3" tailpipes.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
Old 05-07-2012, 01:24 AM   #5
rayfinseats
Pic #3 looks like that would heat up the trans.
rayfinseats is offline   Reply With Quote
Old 05-07-2012, 12:50 PM   #6
61K10
61K10's Avatar
I have a 61k-10 swb/fside sbc V8. 4sp and 221 tf case. I will probably go single in 2 1/2 (will be a stock 350 eng) walker has a nice front y-pipe (2") set up off ramhorns that crosses to the drivers side. plenty of room down that side. one problem i have is the pto driveshaft to the winch, might have to mod the y-pipe. of course i can build it from scratch as i might have to. also thanks for the pics-----
1961 chevy K10
Old 05-07-2012, 01:08 PM   #7
dennislbrooks
dennislbrooks's Avatar
67 k10
dennislbrooks is offline   Reply With Quote
Old 05-07-2012, 02:24 PM   #8
SunSoaked
SunSoaked's Avatar
Well you had to ask. I know, but times are tough...lol..
SunSoaked is offline   Reply With Quote
Old 05-07-2012, 10:34 PM   #9
Mr. 250r
Mr. 250r's Avatar
Not a thread steal by any means but boz is your exhaust spot welded? and is that a diy4x inboarding shock kit? if so hows it work
as far as exhaust i HAD 91 suburban single stock exhaust with a glass pack that sounded perfect unfortunately i will be changing it to dual
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 05-08-2012, 11:44 AM   #10
61K10
61K10's Avatar
post up any exhaust--might give somebody some ideas.
1961 chevy K10
Old 05-08-2012, 12:11 PM   #11
Burt4x4
Burt4x4's Avatar
I have Thorley Tri-Y headers, H pipe right behind the Xfer case and two 50series Flowmasters. I have a HUGE 37gal gastank that takes up all the room right behind my rear axel so the exhaust guy had to route my tail pipes out side the frame to just behind the bumper. I told him make it high & tight and he did an awesome job. That and it's way secure..no shaking or wiggling anywere!! Solid! I had simple turn downs on my old exhaust and on the trail it sucked as MAJOR DUST blew out from under me..the guy behind me didn't like it too much also
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 05-29-2012, 08:34 PM   #12
boz42
boz42's Avatar
The collector joint is slipped over the outside of the collector. It is a type of "V" flange. It slides over several inches & is a very tight fit. Only a few spot welds are required to hold it in place. It does not leak. That is the only place that is spot welded.
Yes it is a DIY4x inboard kit. I like it. Just remember you need much stiffer shock rates when your shocks are inboard. Even stiffer when they are leaning.
Sorry for the slow reply. I don't hit the innerweb every day.
Old 05-29-2012, 08:36 PM   #13
boz42
boz42's Avatar
Looks that way, but i don't have any issues. I run a temp gauge in the pan to keep an eye on it.
Old 05-30-2012, 08:38 PM   #14
thirdstreettito
Resident of Here
thirdstreettito's Avatar
[IMG]http://i220.photobucket.com/albums/dd239/K5Boz/K5%20build%20pics/P6150046.jpg
[IMG]http://i220.photobucket.com/albums/dd239/K5Boz/K5%20build%20pics/P6150045.jpg
Mine dumps there too. I cut the stock muffler out and welded a summit street/strip 3in/3out muffler in with a bend from the cut off exhaust for a turndown. stock 2.5 off the manifolds down to a crappy Y into stock 3".
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
