Old 04-13-2012, 03:20 PM   #1
**grumpy**
**grumpy**'s Avatar
need pic of front draglink and tierods asap!
Something seems wrong with my 64.
I need a good pic of how close the draglink? Or whatever the bar that crosses left to right between tierods.
Mine is so close to crossmember and drivers inner tierod damn near touches cm when turning wheels
Road Hounds
**grumpy** is offline   Reply With Quote
Old 04-13-2012, 03:30 PM   #2
**grumpy**
**grumpy**'s Avatar
Re: need pic of front draglink and tierods asap!
Here's pics. Something seems very wrong. The drivers inner tierod actually has been grinding into cm.
Road Hounds
Old 04-13-2012, 03:42 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
Mine is pretty close, but stays within the notched area of the crossmember...
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-13-2012, 03:43 PM   #4
jchav62
1962 C-10
jchav62's Avatar
I don't have a pic on hand, but our '65 seems the same way. Dam close.
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 04-13-2012, 03:48 PM   #5
**grumpy**
**grumpy**'s Avatar
What about the drvrs inner tierod? Mine has actually made gouge marks on cm. Soon as wheels are straight or turned right its touching cm
Road Hounds
Old 04-13-2012, 03:51 PM   #6
**grumpy**
**grumpy**'s Avatar
Best pic I could get of it
Road Hounds
Old 04-13-2012, 03:56 PM   #7
tincan1966
tincan1966's Avatar
This seems to be a very popular thread topic since one was started a few weeks ago about installing PS adapter brackets. Several threads about it. Converted to R & P-no concerns with clearance here.
tincan1966 is offline   Reply With Quote
Old 04-13-2012, 04:00 PM   #8
**grumpy**
**grumpy**'s Avatar
I'm not installing ps brackets or RnP....so how does that reply help me?
I'm laying under truck now. That's why I asked for help asap while I'm staring at it.
Road Hounds
Old 04-13-2012, 07:03 PM   #9
fasteddie1964
fasteddie1964's Avatar
That must be common, my 64 is the same way.
Friends don't let friends drive Fords
fasteddie1964 is offline   Reply With Quote
Old 04-13-2012, 09:31 PM   #10
_1966ChevyPU
_1966ChevyPU's Avatar
For me, the center link is close... but there's enough room that it clears. Right now there's no weight on the front, but there's no indications that the tie rods have hit.
Bryan (Redneck)
'66 Chevy Longbed Fleetside
'12 Dodge Ram 3500
'08 BigDog Pitbull
'11 Cargomate Trailer (Toy Hauler)
_1966ChevyPU is offline   Reply With Quote
Old 04-13-2012, 10:38 PM   #11
**grumpy**
**grumpy**'s Avatar
I've stared at the damm thing for hours while doing front airride stuff.
Can't see anything that looks wrong...it just seems like it looks wrong...in my head.
Not sure what's deal with the drivrs inner tierod rubbing cm, but for now I clearanced at small spot on lip of cm so it doesn't rub.
I'll sort it out later.
But the airride is done...
Road Hounds
Old 04-15-2012, 04:27 PM   #12
bama63
bama63's Avatar
no camera handy but my 63 has enough clearance to slip your fingers between the drag link and cross member also your closest point should be when the wheels are straight ahead and should move away as the link moves on its natural arc
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 04-15-2012, 09:45 PM   #13
Malibob
Malibob's Avatar
just pm'ed you
This statement was made possible by a grant from this station and continued support from viewers like you.
Flickr
Malibob is offline   Reply With Quote
