#5001 | |
Re: What did you do to your truck today?
But thanks for lettin' us see what motivates you. For the most part....as you know.....on this site, when we all say "She's beautiful".....we're talkin about your truck.
Les Hunter '59 3803 someday to be 3853 '63 GMC K1000...351E, TH400 Daily '66 GMC 4000...351C, 5&2 |
#5002 |
Sand casted a plaque for my truck,theres more photos of the process in my build thread:
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
#5003 |
Senior Enthusiast
Installed a rather disappointing gas pedal trim. At least it now looks like a complete set.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
#5004 |
![]() Join Date: Apr 2009
Got My Battery Ripped Off....
Bastards... Tore My Cables Up.... ![]() Posted via Mobile Device
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
#5005 |
Nice build man I like your style!
Posted via Mobile Device |
#5006 |
![]() Join Date: Nov 2010
#5007 |
I used it as a saw horse. Only temporary till I get the other one painted.
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
#5008 |
Really like this car!! I just bought a 72 off from Craigs List. It's under restoration now.
#5009 | |
That looks to be a real clean lil Nova....Blue vinyl and matching interior. That's got a ton of potential. It looks like those are Oregon plates.... Did ya buy locally or drive cross country...? As far as my truck goes....I took the '66 and brought home a generator for a special project....and then...I also used it as a saw-horse.
#5010 |
well I ve been battling this carb all day a new holley avenger gas in th bowl but not jetting anybody have any dynomite
#5011 | |
The 60-66 GMC/Pontiac guy....
![]() Building Genuine Pontiac Firepowered cars and trucks for several decades. ![]() Why Pontiac?? That's just me daring to be different. ![]() Projects.. 63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction. 440CID 2X4 Pontiac ![]() |
#5012 |
Thanks Chris.
#5013 |
Who Me?
I installed my lower ball joints today!! what a task that was.. Im glad the last ones lasted 50 years, I hope these do
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#5014 |
![]() ![]() Round two of Woogeroo vs. the Fuel Pump... 2nd fuel pump of the week... this aggravation makes me want to put a block in it that has a mechanical fuel pump!!! (this engine block came in it) The Easter parking lot install fuel pump was leaking from the body molding of the pump, or something really weird! I used a excess piece of heater hose cut into two, 'C' clip shaped covers to protect the fuel line from the grips... worked great, just a little bit of fuel came out into my bucket. YAY. The difference in road side and driveway repairs is the amount of tools you have! I hope this one doesn't leak! -W |
#5015 |
Took my truck to a show and had a great time. Can't post pics from iPhone though!!
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
#5016 |
![]() Join Date: Sep 2011
Installed the new ECE 2" drop coils in the front. Sway bar and rear coils tomorrow. I'll post some pics then.
Poor and content is Rich...and Rich enough! - William Shakespeare 1966 C10 Custom Cab "Luigi" Big Window - SWB Fleetside 350 V-8 - Powerglide My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894 |
#5017 |
gauges baby! Painted the dash and then put the gauges in...Took'r for a spin today too...Man Im ready for small town weekend...First Week of June in El Reno...All you Okies should come..Any Ideas on what to do with my holes in the dash??? I made some aluminum void plates today but Im not sure If I like them or not..
#5018 |
![]() ![]() Join Date: Oct 2011
Got the cab striped down.
![]() ![]() ![]() ![]() Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" ![]() Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
#5019 |
Finished rewelding my pass side rocker on properly and repaired floor mount then sealed/primed and undercoated the bottom of pass side floor and inner rocker then fitted my door so it is close but need a bit more hinge work, the new busings helped too, will post pics when done door.
#5020 |
Senior Enthusiast
I really sympathize with you. Over the years I’ve had a variety of electric fuel pumps from dirt cheap to very expensive. Regardless of brand, type or orientation of filters I’ve never owned one that didn’t fail – eventually. I’d love to have an electric pump right now to assist in starting after the truck sits for several days, but I just can’t tolerate the dependability of electric pump failures. By comparison, my mechanical pump has been in place for 20 years and still works fine.
#5021 | |
![]() Quote:
![]() -W p.s. read my truck site in sig line if ya want details about my plain jane motor. |
#5022 |
![]() Join Date: Apr 2012
Install new rear cross sill on my 64
I have not failed. I’ve just found 10,000 ways that won’t work. |
#5023 |
Fixed the interior light, learned in the process that the light switch needs replacing. Looped my heater hoses together so that my next job can be to remove and restore the heater box.
Hey, can I just plug the heater inlet/outlet at the water pump? Also, installed a new steering wheel, the old walnut wheel was coming apart a bit ( got a few nasty pinches from that one). Not thrilled with how that turned out. Previous owner installed a horn button on the steering column, when I got it all back together the horn just wants to blow. Must be a short that he had and didn't want to spend the time on. Will need to pull it all apart again and find the trouble. First real day in the grudge with my new toy ![]() |
#5024 |
Repaired the exhaust, set idle and cruised to the strawberry festival
1966 LWB Stepside......SOLD 1963 SWB Fleetside.....Current Project I hate all fords. |
#5025 |
Senior Enthusiast
Yes you can. Just install a correct size pipe plug in both the water pump and the intake manifold. The engine and water pump don't care if they are connnected to a heater or not.
