04-15-2012, 03:16 PM | #1 |
Parts Interchange help!!!!!
What I've got; 1973 short/fleet.... 3 on the tree, no a/c,disc brakes (not power)
1984-1986 c-10 van....... 73 has a shotty 305 What im shooting for; 350/350 swap from van into c-10 Power Disc Brakes Parts im hoping interchange; Radiator Steering column Brake pedal assembly Master cylinder/brake booster Sway bar Wheels Possibly rear end Transmission crossmember If I've left something out don't hesitate to let me know..... Im going for the engine/transmission swap,the automatic conversion, and the power Disc brake upgrade..... Help,comments,suggestions......anything to help me avoid problems up ahead..... Posted via Mobile Device |
04-15-2012, 05:20 PM | #2 |
Robert Olson Transport
Re: Parts Interchange help!!!!!
the motor and trans will go right in.. Im reasonably certain its the same power booster that would be there in the pickup. I dont think the pedals will work but i could be wrong but for the conversion you dont need to do the pedal swap.. you can just remove the clutch pedal and call it good im not sure about any of the other parts
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
04-15-2012, 06:04 PM | #3 |
i'm pretty sure that the steering column is gonna be too short and the van frame is wider than the truck frame. the wheels will work
04-17-2012, 05:34 AM | #4 |
Ok thanks fellas!
04-17-2012, 11:27 AM | #5 |
1984-1986 c-10 van....... 73 has a shotty 305 What im shooting for; 350/350 swap from van into c-10 Power Disc Brakes Parts im hoping interchange; Radiator-----------------------Most possibly Steering column---------------Not even close Brake pedal assembly----------c above Master cylinder/brake booster--c above Sway bar----------------------Just might Wheels------------------------BOLT ON Possibly rear end---------------Nope Transmission crossmember------Notta, But you don't need one anyway, just move your current one back.... If I've left something out don't hesitate to let me know..... Im going for the engine/transmission swap,the automatic conversion, and the power Disc brake upgrade..... Help,comments,suggestions......anything to help me avoid problems up ahead..... ----------------------------- As a side note, the brake pedal is diff from a power brake truck to a non power brake truck. My plan would be buy the van, remove motor/trans/radiator. Sell the column to the 67-72 guys, scrap the rest and buy the correct parts you need ... |
06-12-2012, 10:29 PM | #6 |
Spindle --->out? Rotors /calipers /?????????
The neighborhood Dennis the menice thought it would be funny to take everyones lug nuts this past weekend.... Lost front wheels doing 60......... Glad i had rear brakes Posted via Mobile Device |
06-12-2012, 11:17 PM | #7 |
So, what's different with the pedal from power to non power. I swapped and only had to change the push rod. No stopping issues at all. I do understand the difference from auto and manual trans pedal.
06-13-2012, 02:46 PM | #8 | |
On a quite night you can hear a ford rust |
06-14-2012, 07:24 AM | #9 |
From what Ive noticed its the throw length and the size of the hole where it connects to the pedal.
1973 k20 Suburban 350 1974 Custom stepside c-10 250 1975 Chevy stepside 454 1986 K30 Crewcab SRW 350 R.I.P- glimmertwin01- board member and good friend, you will be missed |
