Old 04-16-2012, 07:12 PM   #1
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
Are these holes in my firewall from the factory?
I have 2 holes in the floor of the passenger side of my cab that are about 10" apart. Around where the passenger's feet would be if they had their legs straight out. They look exactly like the antenna hole thats on the upper cowl. (just looks like they blew through instead of drilling.) if they are stock, what are they for?? Thanks. Sorry for the crappy pictures...
-NICK
'72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation
'89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205
'15 Chevy 2500HD CCSB High Country Duramax
'22 Tahoe Premier Duramax
yfs200p is offline   Reply With Quote
Old 04-16-2012, 07:41 PM   #2
JointTech
JointTech's Avatar
Re: Are these holes in my firewall from the factory?
kind of looks like where the bolts that hold the heater core on my AC truck stick through and are impossible to get to without removing the inner fender. But dont quote me on that. I dont know what my firewall looks like that stripped down
72 C20 Long Bed
SB350 TH400 14 bolt rear end
Extremely boring build thread
JointTech is offline   Reply With Quote
Old 04-16-2012, 07:50 PM   #3
Lower
Lower's Avatar
Did the truck have a underdash ac unit?
~Jon
Ol Green 1970 K10ish LWB,454/400/205, been in family since new.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=516056
Lower is offline   Reply With Quote
Old 04-16-2012, 08:08 PM   #4
kev0519
i had 2 bullet holes in that same area
kev0519 is offline   Reply With Quote
Old 04-16-2012, 08:20 PM   #5
100%Chevy
No holes in that part of the floor.
Uploaded with ImageShack.us
Mike.
100%Chevy is offline   Reply With Quote
Old 04-16-2012, 10:19 PM   #6
old Chevy guy
old Chevy guy's Avatar
The cab Im fixing now has those same holes in the floor and there was an underdash ac unit in it when I got it.Looks like someone punched them through with a slag pick. I used a hammer and a dolly and flatend the right one out so I could weld it up. TThis picture is upside down,cant figure the stupid I pod out when you e mail pictures sometimes there upside down. You see what I mean anyway,I think its for a drain.
old Chevy guy is offline   Reply With Quote
Old 04-16-2012, 10:45 PM   #7
100%Chevy
That's why I had mine torn apart.Removing the old underdash a/c.
You can see the condensate drain hole in the hump area and the 2 holes for the lines above in the firewall pad.
They're welded up now(along with the firewall mods) and the factory a/c is in.
Mike.
Old 04-17-2012, 08:40 AM   #8
MLB57
i wonder if thats were the studs were that hold the carpet in place I have two of them on the passenger side
MLB57 is offline   Reply With Quote
Old 04-17-2012, 09:59 AM   #9
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
I bought the cab bare so I don't know if it had AC under the dash. After reading through, I figure it must have. I also have 2 1" holes just to the right of the heater core box that must have been for the AC lines. I guess they're all going to get welded shut since the only air conditioning I'll have is rolling down the windows and opening the rear slider!
-NICK
Old 04-17-2012, 09:41 PM   #10
old Chevy guy
Mine has those holes in the firewall too,near the heater core.
Old 04-21-2012, 06:19 PM   #11
brans72
I have got 2 similar holes on my pass side also like old chevy guy but the hole on left looks more round then his. I pan on filling them in myself.
brans72 is offline   Reply With Quote
Old 04-21-2012, 08:10 PM   #12
Daaaanz67
I have those same holes that your talking about. My truck isa 69 c/10 it has aftermarket a/c the two holes on the floor are drain holes for the condensate lines and the firewall are for the a/c line to pass through. My a/c unit is made by a company callead ARA and it has two drain going through the floor. It looks like they just drove some kind of chisel or large screwdriver throught the floor the didnt even use a drill bit back then.
Daaaanz67 is offline   Reply With Quote
Old 04-22-2012, 11:38 PM   #13
old Chevy guy
The one thats not so round is because I flatend it out with a hammer and dolly so I could weld it up. Didn't get to the other one yet.
Old 04-23-2012, 10:57 AM   #14
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I bet is was underdash a/c.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 04-23-2012, 02:29 PM   #15
omodified
omodified's Avatar
I discovered my truck used to have under dash A/C also. My floor board had the same hole. I used a rotabroach to get rid of the flaring and then inserted a nice thick grommet. Good for now since one side is covered by carpet and the other is covered by the inner fender.
Board Member #87725
Old 04-23-2012, 06:30 PM   #16
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
Thats a pretty good idea. And that way in the future if you ever had to run anything through that side, your grommet is there
-NICK
Old 04-24-2012, 12:03 AM   #17
bartstoy
bartstoy's Avatar
Aftermarket under dash AC. Got one with a grommet and one looks like a bullet hole. Your earlier post made me look.
Original owner '69 C20, long, fleet.
454 BB with Edelbrock stuff.
Work truck for years, 2nd restoration going on.
'69 C20
'03 Tahoe Z71
70 Hp Johnson pushing aluminum bass boat.
All things in life are uncertain, so eat dessert first.
bartstoy is offline   Reply With Quote
