Old 04-18-2012, 10:50 PM   #1
Touchdown67
Touchdown67's Avatar
Rear end gear ratio..
How do you check to see what rear end or gear ratio is in a 1965 1/2 ton C10?
Touchdown67 is offline   Reply With Quote
Old 04-19-2012, 08:24 AM   #2
1963c-10
1963c-10's Avatar
Re: Rear end gear ratio..
Jack up the back of the truck and remove the rear diff cover. Count the # of teeth on the ring gear, count the number of teeth on the pinion. Divide the ring gear # by the pinion gear # and you have the rearend ration. Example: a ring gear with 39 teeth and a pinion with 10 will give you a 3.90 ratio.
1964 Short bed trailer
Old 04-19-2012, 10:25 AM   #3
Touchdown67
Thanks for the info..
Old 04-19-2012, 03:47 PM   #4
MikeN
MikeN's Avatar
95% of them are 3.73's
MikeN is offline   Reply With Quote
