Old 04-18-2012, 11:56 PM   #1
TYoder
69 short bed
Hello Gents, I'm starting my first build with the inspiration that I received from looking at your trucks. While growing up, I remember riding with my grandpa in "old blue" a '72 k10 and knew that some day I would have one of my own. So I picked up a 69 short bed, which was someone's project that fell through. Either from lack of money, time or both.
I know don't say it, the bed is wrong.....thats ok. I dont want a step side anyways.
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
So, on with the truck. It originally came with a inline 6 but some one converted it over to v8. Upon further inspection the motor is a '69 DZ302 from a z28 camaro. I plan on building up a 350 for this build so again. If your interested in the motor let me know.
My plans so far is to strip down to the frame and build from there. I will be updating to power brakes, 5 lug conversion with disk brakes all around. Rack and pinion steering, lowering with springs, fleet side short bed are just to name a few.
1969 C10 425hp Shortbed
My build:
http://67-72chevytrucks.com/vboard/s...=520406&page=3
TYoder is offline   Reply With Quote
Old 04-19-2012, 12:05 AM   #2
TYoder
Re: 69 short bed
I picked up a used 700r4 transmission that I am going to have rebuilt to set behind the 350 block that I acquired. This truck is going to be a driver and 4 speeds with overdrive would be nice for cruising on the highway.
My build:
Old 04-19-2012, 12:53 AM   #3
TYoder
Re: 69 short bed
My build:
Old 04-19-2012, 11:42 PM   #4
TYoder
Re: 69 short bed
I changed the oil and fired the motor up, and I double checked the stamping on the motor. Its defiantly a 302 from 1969 z28. I took a short video of the motor running.
Tomorrow I am going to take the cab off and start stripping down the frame. I found a local guy to media blast the frame, bake and paint....so that's the next step.
I don't know what I want to do for the motor
My build:
Old 04-22-2012, 09:03 PM   #5
TYoder
Re: 69 short bed
My build:
Old 04-22-2012, 09:42 PM   #6
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: 69 short bed
making good progress!
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 04-22-2012, 10:30 PM   #7
TYoder
Re: 69 short bed
I found a local guy that will media blast the stripped frame, bake it, then paint it. Once that is completed I plan on doing a 5 lug conversion, full disk upgrade, high performance suspension all while lowering in the front or rear.
My build:
Old 04-23-2012, 06:56 PM   #8
TYoder
Re: 69 short bed
I found this online and picked it up, I figured it would make a nice addition to my truck. Its original.
My build:
Old 04-24-2012, 01:36 AM   #9
Kyle Martin
Re: 69 short bed
Project looks good man
Kyle Martin is offline   Reply With Quote
Old 04-24-2012, 09:14 AM   #10
TYoder
Re: 69 short bed
My build:
Old 04-24-2012, 09:23 PM   #11
Tinkermc
Re: 69 short bed
looks very nice. I look forward to watching, very interested in 4 wheel disc brakes.
Tinkermc is offline   Reply With Quote
Old 04-26-2012, 09:19 AM   #12
TYoder
Re: 69 short bed
I have been doing some research on rack & pinion steering. I originally thought of doing a manual rack, but decided on a power rack. I want a more responsive feel while turning and quicker lock to lock. I have found some good information and alot of good information on this site aswell.
http://www.crankshaftcoalition.com/w...inion_steering
http://www.longacreracing.com/articles/art.asp?ARTID=13
My build:
Old 04-29-2012, 01:47 AM   #13
TYoder
Re: 69 short bed
I identified a cam that I pulled from another motor on hand its a erson hi flow 11h , and I cleaned up an edelbrock torker II intake as well. I know these are older pieces but they will work for now what im doing. I will also change out the factory valve covers for an aluminum edelbrock set that I have.
My build:
Old 04-29-2012, 02:19 AM   #14
TYoder
Re: 69 short bed
Erson P/N E110521 ,Grind # Hi-Flow IIH ,Advertised duration= 306°I/306°E ,@.050 duration 235°/235° ,gross lift .472/.472 ,108° LC and ground w/0° advance.
This is the cam specs for the above noted cam, it may be a bit much. I don't have a lot of knowledge on cam selection, but im learing.
My build:
Old 04-30-2012, 11:59 PM   #15
trkfrk
trkfrk's Avatar
Re: 69 short bed
Sweet....
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 05-08-2012, 03:01 PM   #16
mcbassin
Still Learning
mcbassin's Avatar
Re: 69 short bed
Cool project. I'm subscribing.
Old 05-22-2012, 10:43 AM   #17
TYoder
Re: 69 short bed
I got off work early yesterday, just in time to get the frame loaded up and dropped off at the powder coater. They are extremely affordable, I hope everything comes out looking great. I will post pics when I get it back. They are coating the frame and the cross memeber for now, more later. I am excited to get it back so I can finally start on the suspension.
http://www.rmlpowder.com/automotive.html
They are located in Ottawa, Kansas
My build:
Old 05-27-2012, 05:38 PM   #18
TYoder
Re: 69 short bed
With the frame getting coated, I figured it would be a good time to clean up the shop, so I pulled everything out. I degreased the floor, now to figure out this 2 part epoxy kit. It shouldn't be too bad. Will post pics soon.
My build:
Old 05-28-2012, 10:30 PM   #19
Tinkermc
Re: 69 short bed
a clean shop makes life easier, but it is the final product that counts and only that. So far looking goood
Old 05-29-2012, 08:36 PM   #20
TYoder
Re: 69 short bed
My build:
Old 05-29-2012, 09:02 PM   #21
TYoder
Re: 69 short bed
My build:
Old 05-29-2012, 09:04 PM   #22
LEX
LEX's Avatar
Re: 69 short bed
The floor looks awesome. I want to do that to mine someday. Was it fairly easy to do?
LEX is offline   Reply With Quote
Old 05-29-2012, 09:19 PM   #23
TYoder
Re: 69 short bed
It was pretty easy, I wish I did a before pic. I was all stained up from oil, grease, dirt etc. Right now it is still curing. The color is almost evened out, the system I used the rust-oleum epoxy shield 2.5 garage. Now that the shop is done the wife wants me to do the garage.
My build:
Old 05-29-2012, 09:56 PM   #24
TYoder
Re: 69 short bed
Getting everything put back together.
My build:
Old 05-29-2012, 10:24 PM   #25
mcbassin
Still Learning
mcbassin's Avatar
Re: 69 short bed
I really like the new shop floor. I hope to use this on my new garage when I build it. Clean shop? what's that?
