Old 04-17-2012, 08:56 PM   #1
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Fan shroud holes won't line up
Any ideas? Here are some pics.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 04-17-2012, 09:16 PM   #2
buz48
Re: Fan shroud holes won't line up
Upside down???
buz48 is offline   Reply With Quote
Old 04-17-2012, 09:25 PM   #3
05crewcab
05crewcab's Avatar
Loosen the radiator hold down brackets and then try to bolt the shroud...maybe that will give you a bit of wiggle room. Then tighten it all up.
1971 C-20 350/350
05crewcab is offline   Reply With Quote
Old 04-18-2012, 10:29 AM   #4
gcburdic
Restoration Virgin!
gcburdic's Avatar
If that's a sbc fan shroud, the bottom of the shroud sits in clips....have you simply tried to lift it up out of the clips some....that's what I had to do to get it to line up
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 04-18-2012, 10:38 AM   #5
shawno72
C/10 junkie
shawno72's Avatar
I think a combination of loosening the rad hold brackets and lifting the shroud up a little should do the trick. Good luck.
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 04-18-2012, 10:38 AM   #6
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I ran out of daylight last night. I am thinking it may have to do with me replacing the rubber in the hold downs. I already trimmed them in half but maybe some more trimming is necessary.
Old 04-18-2012, 10:50 AM   #7
50bomb
50bomb's Avatar
I thinkin same thing about if you had new rubber for the hold downs.
50bomb is offline   Reply With Quote
Old 04-18-2012, 11:54 AM   #8
Lee H
Lee H's Avatar
Are the brackets correct for the radiator, maybe a larger 4 row with stock brackets?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 04-18-2012, 12:41 PM   #9
mrein3
mrein3's Avatar
This happened to me when I installed a 4-row radiator in place of a 2 or 3.
I had to get new "cups" for the bottoms and rubber for top and bottom. When I got done nothing lined up.
I ended up NOT using the factory clips on the bottom. Down there I have cable ties. (You trailer queen folks probably are worried about people looking at the bottom of the fan shround and should look for a different solution there). Using the cable ties allowed some play in the top.
For the top I made little brackets out of sheet metal. (queens will probably want to paint those black.)
Those little "brackets" and cable ties have been in place since May of 2003 with no cooling issues or fan rubbing problems.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 04-18-2012, 02:05 PM   #10
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Did you trim the rubber at all?
Old 04-18-2012, 03:52 PM   #11
mrein3
mrein3's Avatar
Not one bit.
'72 Malibu hard top
Center City, MN
Old 04-18-2012, 04:15 PM   #12
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
You have the 2-3 row upper brackets and what appears to be a 4 row radiator. You need the longer upper brackets and rubbers.
Make sure you also get the larger lower brackets and rubbers too.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 04-18-2012, 04:31 PM   #13
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Gary
This is the same radiator and brackets that were with the truck when I got it and everything lined up perfectly. These are 4 row brackets a have some others to compare them to. I only changed the shroud.
Old 04-18-2012, 07:09 PM   #14
GASoline71
GASoline71's Avatar
Thats odd... shoulda fit just fine.
Gary
Old 04-19-2012, 10:38 AM   #15
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Ok had A minute or two to take another look last night. It must be the shroud. Is there a special shroud for a 4 core radiator with a small block? If you look at the picture below there is no way the gap between the hold down and the shroud can fit because the shroud is flush against the radiator.
Old 04-19-2012, 11:29 AM   #16
GASoline71
GASoline71's Avatar
Is it an aftermarket shroud? Or OEM?
I bought a used OEM shroud because of all the fitment issues with the aftermarket shrouds.
Gary
Old 04-19-2012, 11:53 AM   #17
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Gary
OEM and has the part number on it.
Based on mrein3's post it looks like the fan shroud for a 4 row must be different. I trashed my other one because the ear completely broke off. I should have save it for comparision but I did not expect a problem.
Old 04-19-2012, 12:28 PM   #18
shawno72
C/10 junkie
shawno72's Avatar
The one that mrein3 posted looks to be a 4x4 shroud which is deeper but should mount up the same.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-19-2012, 12:48 PM   #19
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
I didn't notice that but that means it has to be for a small block.
Old 04-19-2012, 02:00 PM   #20
mrein3
mrein3's Avatar
Yes mine is a small block in a 4x4 however the point I was trying to make is that when putting a 4-row in, my shroud lined up EXACTLY like that first picture. My solution was/is to put cable ties on the bottom to allow a little play and make a little bracket for the top.
I don't know if all big blocks got 4-rows or if they used the same shroud as a small block. However to me it appears that there is a "4-row" shroud and a "2/3 row" shroud. Perhaps the parts guys that go through so many of these have seen a difference.
'72 Malibu hard top
Center City, MN
Old 04-19-2012, 03:07 PM   #21
shawno72
C/10 junkie
shawno72's Avatar
Ok I have 2 different types of fan shrouds, one 4x4 and one not. I just went from a 3 core to a 4 core, still have the 292, but in the next day or so I will try both shrouds and see if either one fits.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-19-2012, 03:12 PM   #22
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Let us know. I have seen different aftermarket ones listed for heavy duty radiators. I have a BB shroud wonder if it will work?
Old 04-19-2012, 03:17 PM   #23
shawno72
C/10 junkie
shawno72's Avatar
My shrouds are both oem but try the big block shroud and maybe we can make a faq out of this thread. I will be sure to take plenty of pics.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-20-2012, 10:40 PM   #24
shawno72
C/10 junkie
shawno72's Avatar
Ok here are the two shrouds that I have
And here is the 4 core radiator that I installed last weekend
I was able to install the smaller shroud and it lined top and bottom with no problems, sorry for the crappy pics I was by myself and only had my cell phone but you GW the idea
One thing I did notice is there is this piece on top of the radiator and ifs didn't pull the shroud up over the piece the tabs wouldn't be close enough to bolt up. Maybe that's part I'd the issue. I hope this helps.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 04-20-2012, 10:41 PM   #25
shawno72
C/10 junkie
shawno72's Avatar
The 4x4 shroud won't fit with the six cylinder still in it.
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
