Old 04-20-2012, 08:44 PM   #1
BigA
Lowering my 72 longbed
I have 2 1/2 inch droped spindels and 4 inch lower rear springs that I will install. Now on my oe springs in the back they set at about 10 inches and the new drop springs are the same hight. The question I have is will the new drop springs drop the 2 inches I need or should I go with a 6 inch drop spring. If everything is OK I can not wait to get started. I also plan on getting american tork thrust rims and I'm not sure what backsace to get. I have american soft 8 rims with 3 3/4 back space.
BigA is offline   Reply With Quote
Old 04-26-2012, 07:11 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Lowering my 72 longbed
Install the springs and find out.
If they aren't low enough, try the 6" drop version.
Keith
Convert to disc brakes.
Old 04-26-2012, 08:23 PM   #3
BigA
I plan on doing that but the questions is I think the springs are heavy duty. If so I will go to the normal springs. Plan on doing it all next week and I will send pics, before and after.
Old 05-01-2012, 03:30 AM   #4
Andy4639
Old member
Andy4639's Avatar
Question Re: Lowering my 72 longbed
What kind of weight does the springs claim to have. How much will the spring collapse once on the truck?
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-01-2012, 08:31 PM   #5
BigA
I ORDERED THEM FROM EARLY CLASSIC. NOW MY OE SPRINGS AS THE TRUCK SITS IS 10 INCHES. THE NEW SPRINGS WHICH ARE SUPPOSE TO BE 4 INCH DROP SIT 10 INCHES OUT OF THE TRUCK. PLUS THEY LOOK HEAVER THAN THE PICS OF OTHER SPRINGS FROM OTHER COMPANYS. I WILL PLAN ON INSTALING THEM TO SEE IF I DO GET A 2 INCH DROP. IF NOT, I WILL CHECK AROUND TO SEE WHAT I REALLY DO NEED.
