04-21-2012, 09:01 AM | #1 |
Changing front crossmember
Are there any advantages to changing out the complete frontend as opposed to just changing spindles from donor frontend and draglink and tierods?
Friends don't let friends drive Fords |
04-21-2012, 09:21 AM | #2 |
67-72 parts collector,…
Re: Changing front crossmember
None,... since they started making "year specific" drop spindles for 60-62, and 63-70 drum brake truck owners, that want to install disc brakes.
20 years ago, donor front ends were a good swap,... because they could be found in great condition and installed with no mods. Now all the donor crossmembers are just as wore out (and need to be rebuilt) just like the one in your truck.
04-21-2012, 09:27 AM | #3 | |
04-21-2012, 10:06 AM | #4 |
They will interchange.
I dont think you will notice anything smoother about the ride. Rebuild parts might be slightly cheaper using the 73-87 parts. If you do decide to switch to 73-87 stuff,... get everything. Steering linkage included. No need to change the crossmember though. Just from the a-arms out.
04-21-2012, 10:15 AM | #5 | |
04-21-2012, 10:17 AM | #6 |
Grab the P/S box too,... if he has it.
It's a great way to upgrade to power steering. All you need is a set of P/S frame brackets from member/vendor Captainfab.
