Old 04-21-2012, 06:08 PM   #1
cris well
Brake Booster Bad??
I noticed today that the rubber boot (accordion-looking thing) is split and cracked on my brake booster on my 68 C-10.
The pedal is hard to mash and the brakes won't lock down but they still work (just not properly).
Does the boot seal the air/vaccum or is it just to keep dirt out of it?
cris well is offline   Reply With Quote
Old 04-21-2012, 06:37 PM   #2
hugger6933
Re: Brake Booster Bad??
The boot that you are talking about doesnt hold any air or vaccum just helps in keeping stuff clean. Now the problem you describe does sound like a bad brake booster. Can you hear rushing air as you depress the brake pedal? The hard pedal usally comes from a busted or leaking diaphram iside the booster. It is rebuildable but takes specail tools and is as cheap to repalce with a rebuilt unit
hugger6933 is offline   Reply With Quote
Old 04-21-2012, 06:39 PM   #3
hugger6933
but before you condemn the booster make sure you are getting a vaccum signal to it . If you have heard the air rushing sound that would count as confirmation
Old 04-21-2012, 07:02 PM   #4
cris well
It's getting plenty of vacuum and I can hear a little bit of air squishing but not much (not sure if that is normal or not).
I've put new calipers and a master cylinder on it already but haven't done anything to the rear but replace one leaky wheel cylinder.
Old 04-21-2012, 10:39 PM   #5
hugger6933
Yeah, your hearing air get you a rebuilt booster put in on and enjoy the power brakes and stop working out that leg muscle
Old 04-22-2012, 03:43 PM   #6
cris well
Another question:
It was changed over to 5-lug and disc brakes when I got it and I don't know if it had power drums beforehand or if they used the booster off the 71-72 model truck that the discs came off of.
The parts stores are showing 2 different part numbers from 68 and 71. How can I tell the difference or does it really even matter?
Old 04-22-2012, 05:39 PM   #7
weircc
weircc's Avatar
make sure your back brakes are properly adjusted it will make a huge difference just had this problem this week
1971 rs camaro under the knife ls3 6 speed swap
1970 396 big block shorty fleet 67 clone
2010 rs/ss camaro
weircc is offline   Reply With Quote
Old 05-01-2012, 06:20 PM   #8
cris well
Does anyone know if the brake boosters are different from 68 to 71?
I'm not sure which one is on it--can I tell from looking at it or does it even matter?
