Old 04-22-2012, 08:39 AM   #1
oldchevycarguy
oldchevycarguy's Avatar
Crossmember confusion
I have 78 k5 blazer stock suspension and a 3 in body lift, my question after trying for countless hours to find an answer is should my transmission crossmember be tight to the frame or spaced down just over an inch? The transfer case crossmember that is just behind it is tight to the frame, but the front crossmember is currently spaced.
78 k5 blazer
oldchevycarguy is offline   Reply With Quote
Old 04-22-2012, 09:01 AM   #2
oldchevycarguy
Re: Crossmember confusion
He is a picture of what I currently have, I would like to know if I should take out the spacers, and mount it flush to the frame like the rear one or leave it where it is?
78 k5 blazer
Old 04-22-2012, 07:41 PM   #3
oldchevycarguy
The more I look at this the skid plate on the front crossmember looks bent down on the front edge, you can kind of see it in the picture, unfortunately for me driving around I only saw a two wheel drive blazer so I couldn't even compare it to see how mine should be, so if anyone has a 4x and wouldn't mind taking a look and letting me know, I would really appreciate it. Thank you
78 k5 blazer
Old 04-22-2012, 08:10 PM   #4
justpball
justpball's Avatar
I think my 4x4 burb was spaced down like that...
Fuzzy Dice Club Member
87 Crew SWB
Build for the crew
http://67-72chevytrucks.com/vboard/s...d.php?t=430082
http://www.cardomain.com/ride/3232925
90 burb 2wd
Build Thread For The Burb!
http://67-72chevytrucks.com/vboard/s...d.php?t=383055
justpball is offline   Reply With Quote
Old 04-24-2012, 01:23 PM   #5
oldchevycarguy
Thank you for a reply, when I go to the pics of 4x4 blazers it looks like they are both spaced or neither are, but can't tell 100% if it is spaced and should not be, could that lead to issues? I know that drive shaft angle would be affect moving it up and down, could it lead to engine oil problems with the back down that far and the front then being pulled upward?
78 k5 blazer
Old 04-24-2012, 06:20 PM   #6
russgt
russgt's Avatar
Heres my 76, not spaced
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 04-30-2012, 02:11 AM   #7
Mr. 250r
Mr. 250r's Avatar
from factory those spacers are installed on the top and the cross members sit flush with the frame rails as lifts were so common i can only assume then you just put them on the bottom, in my case it came on the bottom and put them back to factory to tilt my whole driveline up again then again that is on the newer trucks and i've never seen two crossmembers like that before so its somewhat out of my answerable range
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC DRW - Sold
2003 1500 Silverado
2004 Ram 3500 5.9 H.O NV56 CC DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LWB
Mr. 250r is offline   Reply With Quote
Old 04-30-2012, 08:58 PM   #8
russgt
russgt's Avatar
You are correct about the spacers being on top of the frame, mine were.
70 stepside
76 blazer
86 Silverado
71 Nova SS
Old 05-03-2012, 06:50 AM   #9
Some guys move those spacers below the frame in an attempt to change the rear driveshaft angle. It's a weak way to go about it and also makes the front driveshaft angle worse.
Old 05-05-2012, 05:08 PM   #10
oldchevycarguy
I moved the spacers and everything looks better drive shaft angles, the distributor is spaced away from the fire wall and engine looks like it should thank you for the info guys
78 k5 blazer
