Old 04-23-2012, 01:28 PM   #1
WTexChevy
WTexChevy's Avatar
Theft Prevention
I getting close on having the truck ready for paint and then comes interior, stereo and a/c. I'm wondering what you guys are doing along the lines of theft prevention.
Thanks!
WTexChevy is offline   Reply With Quote
Old 04-23-2012, 01:49 PM   #2
Batchief909
Re: Theft Prevention
Springfield 1911....
Batchief909 is offline   Reply With Quote
Old 04-23-2012, 01:56 PM   #3
k1rodeoboater
Agreed. Big 1911 Fan.
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201
no garage, no shop, limited storage space and tools....no problem.
k1rodeoboater is offline   Reply With Quote
Old 04-23-2012, 02:17 PM   #4
A.T. RockDriller
A.T. RockDriller's Avatar
Well, WTex....
In my case....I just leave it so unpleasant to look at, that folks just naturally move on to the next candidate...
The truth is....like the rest of us...the first line of defence is in the catagory of fire arms...
But to answer your question...
As we all understand....if they really want it....and you leave it unattended in a bad place...it's history.
For protection from the quick thief..I have two seperate disconnects.
The kind that are made for marine applications....I usually only use the one that's easy to get to....for a trip to the store or under a couple hours, in a public area. That one is just to interrupt the power to ignition.
I have a larger one...High Amp...harder to get to that cuts main power from the battery. That's for parkin overnight...or fishing trip, or whatever.
Niether of them are that effective, if someone really wants it. But they will slow a thief down...make it more difficult for him.
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 04-23-2012, 02:39 PM   #5
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
Here is a couple of threads I have been following, so when I get to that point, I will have some ideas. You may be able to search up some more threads too.
http://67-72chevytrucks.com/vboard/s...d.php?t=517525
http://67-72chevytrucks.com/vboard/s...d.php?t=492444
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 04-23-2012, 02:42 PM   #6
1963c-10
1963c-10's Avatar
12ga and a .44 work for me.
1964 Short bed trailer
Old 04-23-2012, 02:49 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
I have a chain lock on the hood, the gas filler is locked under the bed cover, and a Hotronics remote master disconnect cuts off the electrical every time it’s not being used (even in the garage). I like leaving the truck electrically dead because it cancels any potential electrical problems unless I’m present to witness the issue. Keeping the battery and gas secure can at least help you from being left stranded if either it stolen or tampered with.
As Rockdriller points out these are only deterrents. The best protection is keeping it in a locked garage every night and not taking it to high risk locations and leaving it unattended. Since mine is a retired hobby truck now that’s pretty easy, but when it was a full service driver it wasn’t quite so simple.
A removable steering wheel might also be a good deterrent if you have someplace to lock it up.
Here’s the Hotronics solenoid. Bummer they were only $89.00 back when I bought mine.
http://hotronicsproducts.com/product...cf6709012b5ebe
And here’s a link showing how I lock the hood:
http://67-72chevytrucks.com/vboard/s...highlight=hood
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-23-2012, 03:50 PM   #8
spacedebris
I use 3 disconnects.
Under the hood I have a battery disconnect and a coil disconnect.
And on the inside I have a fuel disconnect switch.
For quick trips and just running around, I just use the fuel disconnect.
I also installed a Lo Jack device during the reconstruction of the truck.
I plan on adding all 4 to my 60 panel as well when the time comes.
spacedebris is offline   Reply With Quote
Old 04-23-2012, 04:25 PM   #9
A.T. RockDriller
Good call...
I would say that anyone with a budget that can stand it....Nothin like Lo-Jack.
That's the state of the art, and as close to tweaker-proof as you can get, and if you combine that with these simple deterrants....you might be able to keep yer truck from being jacked.
The sick truth....there is definately a black market for these vintage trucks overseas...where they are less likely to be found through conventional methods.
Take yer truck, stick it in a 20' container...an she's gone for ever.
Les Hunter
Old 04-23-2012, 05:45 PM   #10
62 short step
62 short step's Avatar
Good insurance. Thats about it.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 04-23-2012, 06:56 PM   #11
WTexChevy
WTexChevy's Avatar
Thanks guys! I'm thinking a hidden starter/ignition disconnect might be the easiest thing to do.
Old 04-23-2012, 07:48 PM   #12
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
If it's four on the floor like mine, the gear shift comes right out. You can pack it around with you as added protection to hit any bad guys that might approach you.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 04-23-2012, 08:39 PM   #13
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
That's a solution I hadn't thought of.
Jason
Old 04-23-2012, 10:05 PM   #14
forestb
forestb's Avatar
I here that the lock that goes between your floor boards and you break pedal are extremely difficult to get off.
forestb is offline   Reply With Quote
Old 04-23-2012, 10:42 PM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Usually just the keys and a few firearms lol....but I have a rope-lock for the hood, and my ecm is on quick mounts so one bolt and its out in about 20 seconds for leaving it somewhere for a few nights.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-24-2012, 12:33 AM   #16
laynrockers
laynrockers's Avatar
On one of my last builds 03 chevy avalanche layd frame on 27"s with complete stereo. I had three hidden keys.
what was unique about them was that its not just a switch you can hit, it required a special hex key to turn. I did one for the fuel cell, one for ignition, and one for main battery. Each was hidden.
Since it was my daily driver I hid two inside the cab. I installed a escalade center console, and in the bottom it had a rubber black cd case, under that i hid two of them.
It was annoying but after 6 break-ins no one ever got the truck only a few amps or subs every now and then!!
laynrockers is offline   Reply With Quote
Old 04-24-2012, 01:16 AM   #17
70cst
70cst's Avatar
Good info ...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 04-24-2012, 01:41 AM   #18
Mike Bradbury
Mike Bradbury's Avatar
Poor man low jack; Get one of those inexpensive track phones that you have to load minutes on, then plug the track phone's GPS into your smart phone app. Then hide the phone somewhere on your truck so that you can keep it charged up at all times. Even if the thieves unplug the battery you still have a couple of days before the cell phone goes dead. I am going to hide mine in a dummy section of heater ducting, it has to be somewhere that even if they were taking your stereo they would not notice it until you show up with the police.
This way if your son or daughter ever use the truck you will know where they are.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale
Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961
Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583
Mike Bradbury is offline   Reply With Quote
Old 04-24-2012, 09:40 AM   #19
LT1 Burb
LT1 Burb's Avatar
All I have is good insurance and have never really worried about it.
LT1 Burb is offline   Reply With Quote
Old 04-24-2012, 10:08 AM   #20
koda360
koda360's Avatar
Well, now that we know everyone's secrets...... lol
1960 C-10
2000 Dakota R/T
1966 Fury I 2dr post
1984 Big Bronco
2002 Durango SLT (Bride's Ride)
koda360 is offline   Reply With Quote
Old 04-24-2012, 10:16 AM   #21
FreakyMalo
FreakyMalo's Avatar
I've used the cigar lighter as a 'hidden' switch. Disconnect the hot wire from it and connect the ground wire from fuel pump relay to the terminal on the lighter. Push it in and the fuel flows, pull it out and nothing.
Also works when attached to the negative side of the coil. Push it in and it grounds the coil so the engine won't run. Pull it out and it runs normal.
66 Carryall
my photos
FreakyMalo is offline   Reply With Quote
Old 04-24-2012, 01:53 PM   #22
A.T. RockDriller
Well, Robert....I like that idea....
The problem is....I swapped my SM420 fer a TH400....with a column shift.
I guess I could just use my drive line.
Les Hunter
Old 04-24-2012, 03:36 PM   #23
**grumpy**
**grumpy**'s Avatar
I had a bagged 62 Belair and it was wired so you HAD to have the parking lights on for car to start/stay running.
Everyone always thought I was trying to be cool with my running lights on all the time...
Road Hounds
**grumpy** is offline   Reply With Quote
Old 04-24-2012, 05:23 PM   #24
awbrown
X2 on this one this is the route I will take .. Lots of guys with motorcycles use this method and as long as it is hidden well the next thing the theif sees it blue lights... or my .45
awbrown is offline   Reply With Quote
Old 04-30-2012, 01:10 PM   #25
Scot_Douglas
Scot_Douglas's Avatar
I went with a hydraulic clutch and have the manual bracketry remaining - the one that connected to the pushrod and keeps the clutch pedal shaft located. I welded a bracket to the inside of the firewall right next to it with a corresponding hole for the original linkage.
Park the truck, put a padlock through the brackets and nobody will be able to operate that clutch. And that's assuming they can find the tricks to get the engine started.
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
