Thinking of building a custom Grille
Any thoughts, ideas or opinions ? It would look mostly like this .
Re: Thinking of building a custom Grille
The 60-61 chevy and 60-66 gmc had dual headlight grills. As did alot of the larger trucks. I am partial to the 63 grills, but have always liked the dual headlight grills. Are you planning on using the aluminum or steel grill. With two large lights on each end, definitely should be enough light.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
But then it will say "hevrole"..... j/k I always liked the dual headlight grills
Normally the dual headlight grills use the smaller lights. Im not sure how it'll look with the larger lights. The bezels are going to be hard to fab up.
#5 | ||
![]() Quote:
Can't wiat to see it. I think going with the grills w/o the Chevrolet is the way to go.
Thanks but I'm really just mulling this idea over. I also was thinking about a 60 Ford Starliner grille . But I really l enjoy doing a kustom mod that looks like it could have come from the factory .
Heres a 64-66 grill that was "modified". Im not a fan of what was done here, but somebody else's idea of a modified grill. From what I can see....at least 3 different grills here.
It just looks unfinished to me. I applaud anybody trying to invent or modify anything. But the grill in question just looks "uncomplete" somehow.
it almost has the look of 67-72 gmc truck grilles
'66 chevy lwb c10 '65 chevy lwb c20 |
Here are a few pics of mine. used the upper part of a 4 5 6 steel grill and some head lights from a 59 imperial. It still says Chevrolet in the middle.
86 K20 6" lift 66 C10 LS2 T56 1947 Ford Rat Rod Softail Deluxe Softail Chopper |
![]() Join Date: Oct 2009
regarding the picture in Post #1, i think it would only look complete if you add 2 more headlights on each side, paint it green, add faux woodgrain panels all along the sides and get Chevy Chase's autograph on the glovebox...
Sorry, couldn't resist. I agree with most, those bug eyes are too big - if you want to go custom 4 headlight approach, I think movieauto's approach with the smaller lights looks much, much better. My 2 cents only, I too admire the ambition! |
#15 | |
#16 |
This thread has some good stuff. Post 8 looks killer I think!
http://67-72chevytrucks.com/vboard/s...d.php?t=402277 Posted via Mobile Device
#17 |
#18 |
humor is sometimes a good thing on this site - some moviegoers might appreciate the levity, but it was certainly not intended as sarcasm or negative in any sense, so I apparently failed miserably in my humor attempt. I DO admire your effort and your plan, the constructive part of the post was simply to suggest smaller headlights.
#19 |
I say go for it! Im a big fan of custom or different then the norm...What can go wrong? you make it and install it and you decide you dont like it swap it back out and wasted some time and a couple grills...or it turns out pimp and you rock the new grill
Timmy D. "What that grinding noise?Don't worry about that it will eventually clearance itself!" 1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977 1954 ford customline H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142 |
#20 |
meowMEOWmeowMEOW
Not my truck, but jacked it for the front pic to use. Did a quick photoshop....a bit strange but I kinda like it, if I have to cram an inercooler into my grill
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
#21 | |
#22 |
Never Ending Projects
This was done on a truck I got from a buddy. A neighbor built this for him back in the 70's. Can't recall what the headlight buckets were from but I think a Buick or Olds.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#23 |
Heres a few more
#24 |
No worries! All good to go. If this didn't happen accidentally every once in awhile, well, "I would not be more surpised than if I woke up in the morning with my head sewn to the carpet"
#25 | |
Here's a four light grill that looks pretty good on a Chev pick-up.... ![]() There's a jack@$$ in every croud. It seems to be me, right now.
Les Hunter '59 3803 someday to be 3853 '63 GMC K1000...351E, TH400 Daily '66 GMC 4000...351C, 5&2 |
