04-25-2012, 02:22 PM | #1 |
WTB 3/8" fuel lines and air cleaner for 70 BBC truck
I bought a 70 Longhorn with a 400 BBC that was set up for propane with no fuel pump and I am swapping it to run on gasoline. The P.O. installed a Qjet and I have a stock in cab tank out of another truck, but I need the 3/8" fuel line that runs from the in cab tank to the fuel pump and the line that runs from the pump to the carb (Q-Jet). Inline Tube sells these for $60 and $20, so worse case I can get new ones for $80 + shipping, but figured I would try here first to see if I could save some $.
I am also looking for a stock air cleaner set up for the same truck. Let me know what you have including shipping to Leander Tx 78641 |
04-25-2012, 08:12 PM | #2 |
Re: WTB 3/8" fuel lines and air cleaner for 70 BBC truck
I purchased a air cleaner housing and riser yesterday from another member which should be arriving in the next few days. Last night going through some old parts guess what I found? Air Cleaner from one of my previous trucks(69 suburban). If this is what your looking for I am in Austin so would not have to ship. I didn't see the top but I didn't search too hard for it and if that's what your needing I can check.
Posted via Mobile Device |
04-25-2012, 08:23 PM | #3 |
If it is from a big block truck i am interested. Do you have an idea what you want for it? Do you have any photos?
04-25-2012, 08:29 PM | #4 |
It came off my quadrajet wasn't a bb though, not sure if the were the same. As long as the other one ordered comes in fine I have no need for it, yours if you want it no charge. It's in cedar creek where I'm doing my build and will be out there tomorrow. I can grab it and send pics then if need.
04-26-2012, 02:13 PM | #5 | |
04-26-2012, 02:14 PM | #6 | |
If it is from a big block truck i am interested. Do you have an idea what you want for it? Do you have any photos? |
04-26-2012, 02:23 PM | #7 |
Junior Member
you can get the tubing and fittings from Oriellys for $6 and all you have to do is bend it, the ends are all ready flared and fitting for the fuel pump and carb installed
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
04-26-2012, 04:44 PM | #8 |
I referring to the stock air cleaner set up at the end of your request not the lines.
05-03-2012, 10:44 PM | #9 |
Ttt
05-03-2012, 10:51 PM | #10 |
VA72C10
I have a correct bb air cleaner with spark arrestor. 120 shipped.
Looking for a 67-72 swb or blazer project in or around VA. |
05-04-2012, 12:20 AM | #11 |
05-04-2012, 03:55 PM | #12 |
05-05-2012, 10:17 AM | #13 |
WIDESIDE72, I thought someone would describe the difference in the air cleaner of a BB and a SB, but must be a secret only know to a few good men! I'll go out on a limb and say there isn't anything different other than the spark arrestor, the downdraft tube and the manifold heat shroud, between them. Just sold a very nice one at the Charlotte Auto Fair.
Hope someone can help with this question! Thanks, Dan |
05-05-2012, 10:23 AM | #14 | |
Moderator
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
05-05-2012, 01:47 PM | #15 |
VA72C10
I don't have a small block one right now so I couldn't compare and honestly never thought to before...makes sense that they're similar though...
05-16-2012, 02:39 AM | #16 |
Ttt
