04-24-2012, 03:36 PM | #1 |
Next!
Rivet shortage
I've parted out a lot of trucks over the years but this is the first one I've found where ALL the spring hangers and the mid mount support were
supported by bolts and not by rivets. Its an 85 K30 CUCV and I'm sure no one was that bored to have replaced all the the spring hangers and bracing. The only riverts on the truck are for the engine cradle. Must have ran out of rivets that day and used bolts, Keith?
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
04-24-2012, 03:45 PM | #2 |
Re: Rivet shortage
Wow that is definitely interesting. Believe it or not I was thinking about cutting out the rivets and putting in bolts so I could sandblast every nook and cranny before I get the frame coated. But way to much work and I dont want to mess with the structural integrity of the frame.
1986 GMC K15 4.3V6/SM465/NP205 will be converting to 5.3LS E-ROD/AA adapter/SM465/NP205 10 Bolt Axle Rebuild Tutorial: http://67-72chevytrucks.com/vboard/s...d.php?t=536415 |
04-24-2012, 04:11 PM | #3 |
Robert Olson Transport
Re: Rivet shortage
interesting.. i wonder if at some point the truck was a total or a 4wd conversion?
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
04-24-2012, 07:15 PM | #4 |
Re: Rivet shortage
I parted out a 87 suburban 4x4 and it was the same way, all bolts except the engine cradle.
1981 Dodge D-150 (under construction) 2007 Chevy Suburban 2010 Dodge Charger R/T 1980 Kawasaki KZ 440 2004 Harley Sportster 1200 |
04-24-2012, 09:25 PM | #5 |
Next!
Re: Rivet shortage
CUCV bought from State of Pa so its not a conversion.
04-25-2012, 06:44 AM | #6 |
Re: Rivet shortage
I wish mine had been bolted in to start with. just spent two days knocking out rivets to swap all my spring hangers over from my 4wd frame to my new 2wd one.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
04-25-2012, 08:29 AM | #7 |
Re: Rivet shortage
Looks like a repair to me; they may have put the hanger in the wrong location initially, and then after it was past the rivet station they had to cut the rivets out and bolt the hanger in the correct spot. Said differently, the approved repair procedure was to replace any defective rivets with a 3/8" bolt - and the only explanation for having all the rivets replaced would be because the hanger had to be moved.
Additionally, the military trucks were few(er) and farther between the regular trucks (like maybe one out of every 12), plus there was a lot more complexity (so folks were not as happy to see them coming), so they were easy to mess up. That's another data point that would suggest a build error. As an aside, because I knew I was going to be lowering my truck by moving the hangers; when my truck was built I tried to persuade the workers to bolt all my hangers on rather than rivet. No luck on that one....
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 04-25-2012 at 08:38 AM. |
04-25-2012, 10:05 AM | #8 | |
Re: Rivet shortage
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
04-25-2012, 09:11 PM | #9 | |
Next!
Re: Rivet shortage
Thanks for your answer, parting this truck out anyway, little easier with the bolts!
04-26-2012, 09:51 AM | #10 |
Re: Rivet shortage
I would say the truck had been rebulit since it is a CUCV.
1949 Five Window, 1973 Step Side, 2000 Z71 |
