Old 04-27-2012, 07:24 AM   #226
CuRtdOgG
CuRtdOgG's Avatar
Re: My 85 chevy c10 build
Plan on doing a little work today...iv been working longer hours and havent really had extra time lately...I am needing to drive this truck Soo bad!!
CuRtdOgG is offline   Reply With Quote
Old 04-28-2012, 05:03 PM   #227
CuRtdOgG
CuRtdOgG's Avatar
So I did a little..I took my air tank sanded it and cleaned it up and painted it black. I also discovered I need all new cab mounts and bolts along with bed bolts...I also need to get the trans crossmember...moose..where did u order yours from? I need to get fuel pump filter, fuel lines and trans lines. I'm also working on the bed...I took some pics.
IMAG0442 by catkinson896, on Flickr
IMAG0434 by catkinson896, on Flickr
IMAG0439 by catkinson896, on Flickr
Old 04-28-2012, 05:06 PM   #228
CuRtdOgG
CuRtdOgG's Avatar
IMAG0443 by catkinson896, on Flickr
IMAG0446 by catkinson896, on Flickr
Old 04-28-2012, 08:40 PM   #229
legendman
legendman's Avatar
Nice, making some good progress.
1999 Chevy K2500 RCLB 350 4L80e
2004 Chevy 3500 C&C Dmax Allison
Originally Posted by smackzed View Post
I put a chevrolet tailgate on my last truck and it started acting like a girl...love me, need me, want me pay attention to me. Took it off and put the GMC back on (fixed the latch) and it went back to being the same old dirty bastard it used to be
legendman is offline   Reply With Quote
Old 08-05-2012, 01:25 AM   #230
CuRtdOgG
CuRtdOgG's Avatar
IMAG0580 by catkinson896, on Flickr
IMAG0582 by catkinson896, on Flickr
IMAG0584 by catkinson896, on Flickr
Got this thing in my garage now. I can start re-wiring the switches. Mount the airtank on the frame on the pass side and install the compressors on the rear. Then re-do the hoses and wire it up so the suspension is ready to go. Then onto the motor. Then body work and then will be time for a cruise!
Old 08-05-2012, 04:18 AM   #231
CuRtdOgG
CuRtdOgG's Avatar
Just finished mounting the first compressor. Got it all wired minus the pressure switch wire. Gotta wait till I mount the tank and move some airlines for that. Went pretty well. I'm happy with it and this way everything will be hidden under the bed mounted on the frame!
IMAG0587 by catkinson896, on Flickr
IMAG0585 by catkinson896, on Flickr
Old 08-06-2012, 04:55 AM   #232
CuRtdOgG
CuRtdOgG's Avatar
Just finished getting both compressors mounted. Got them all wired up except for the two wires that go to the pressure switch , which ill do once I mount the tank. And I mounted the air filters on the inside of the frame rail.
IMAG0588 by catkinson896, on Flickr
IMAG0589 by catkinson896, on Flickr
IMAG0590 by catkinson896, on Flickr
Old 08-06-2012, 10:31 AM   #233
maxxxy
maxxxy's Avatar
Looks good! Will your tank fit in between the rear frame rails? If it did, I'd think that'd look better and be easier to later access all the compressors, tank, and valves, if they were in the same place, rather than on the passenger side. I mean mine is on the passenger side, so there's nothing wrong with it being there. Lol.
Max
Max's bagged 81
81 rcsb bagged, 22s, build in progress
09 ext cab, 24" U2's, DD sub/amp
maxxxy is offline   Reply With Quote
Old 08-06-2012, 02:47 PM   #234
CuRtdOgG
CuRtdOgG's Avatar
It is too wide. Or I would. I'll look maybe I could figure out a diff spot i dono yet.
Old 08-06-2012, 02:51 PM   #235
okndnx
You should think about mounting your compressors with the heads upright
okndnx is offline   Reply With Quote
Old 08-06-2012, 04:14 PM   #236
CuRtdOgG
CuRtdOgG's Avatar
Do they not work on their side?
Old 08-09-2012, 01:14 AM   #237
maxxxy
maxxxy's Avatar
This is straight from the viair website.
Q: Is it possible to mount VIAIR compressors sideways, or must it be mounted with the cylinder upright?
A: You can mount in any direction or position since VIAIR compressors are oil-less. The only position we do not recommend is an upside-down mount, since heat tends to travel upward, and does not dissipate well in the motor housing. A sideways mounting may reduce the life of the piston seal, since everything is governed by gravity and has a weight associated with it.
Max
Max's bagged 81
Old 08-10-2012, 10:22 PM   #238
CuRtdOgG
CuRtdOgG's Avatar
Thanks max. I think ill leave them there. They fit nicely and will be hidden!
Old 08-16-2012, 08:37 PM   #239
king-918
king-918's Avatar
glad to see others here around the city doing this too!
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 08-17-2012, 05:00 PM   #240
CuRtdOgG
CuRtdOgG's Avatar
Your doing the same! Nice. I'll check your thread out
Old 08-20-2012, 10:47 PM   #241
luifer76
luifer76's Avatar
looking good curt are you gonna paint the frame while you have it all apart?
nOtHiNg LiKe ThE gOoD oLe ChEvYs....
luifer76 is offline   Reply With Quote
Old 08-22-2012, 03:10 AM   #242
CuRtdOgG
CuRtdOgG's Avatar
I wish I would...but how much work would that be...im jist lazy man. I dread taking all the lines off and the work....but I should get over it and do it...it would be way better huh...how long do u think that would take?
Old 08-22-2012, 03:12 AM   #243
WarBeard
WarBeard's Avatar
Lazy is painting the frame with the lines on it
1978 C10 Silverado Big 10 350/350.. play toy
1990 V1500 Suburban 350/700r4..Daily driver
1987 K10 Silverado 383/400.. Wife's rig WRECKED!
1989 V2500 Suburban 350/400.. SOLD!
1974 C10 Custom10 LWB 350/350.. SOLD!
1974 C10 Custom10 SWB 350/400.. SOLD!
1999 Silverado Z71 LS1.. Wife's rig WRECKED!
On the hunt for a new project.......
I'm a Chevy guy.....I'm just not a "NEW" Chevy guy.
WarBeard is offline   Reply With Quote
Old 08-24-2012, 12:05 AM   #244
luifer76
luifer76's Avatar
if i was you and i had the frame by itself just laying there i would yank all the lold wires out of there and take all the air ride stuff off and paint everything and even if it took you a little longer than what you want, you will feel better about it and you gonna be glad you did it while it was all apart beacuse i can almost guarantee that you gonna wish you did it but than its gonna be too late cause you gonna have the truck all put back together... been there done that.... i always rush and than wish i would have done it different later.
Old 08-27-2012, 05:37 AM   #245
CuRtdOgG
CuRtdOgG's Avatar
I'm gonna do...i guess all I got is time. It will be awesome in the long run. Thanks guys
Old 08-28-2012, 12:56 PM   #246
king-918
king-918's Avatar
Where are you at? Anymore pictures?
<----Christopher
Oklahoma
Old 08-28-2012, 04:19 PM   #247
luifer76
luifer76's Avatar
sweet post pics lol....
Old 08-29-2012, 11:43 AM   #248
CuRtdOgG
CuRtdOgG's Avatar
Well i got the airlines and switch solenoids off. Not much but some progress...i just need to take the fuel lines and tank off then the front end and brake lines then start prepping for paint. not much but heres a few pics.
IMAG0614 by catkinson896, on Flickr
IMAG0613 by catkinson896, on Flickr
IMAG0615 by catkinson896, on Flickr
Old 08-29-2012, 09:27 PM   #249
luifer76
luifer76's Avatar
moving forward bro ..... looks good.
Old 10-13-2012, 03:26 AM   #250
CuRtdOgG
CuRtdOgG's Avatar
really need to quit being lazy and do some work....
