Old 04-26-2012, 06:49 PM   #51
newbe351
Re: How many still have stock tank in place?
Where we at now, 40? I like my spare....
newbe351 is offline   Reply With Quote
Old 04-26-2012, 07:05 PM   #52
losthope
losthope's Avatar
Originally Posted by kc0kfg View Post
Well first thank god you are alive,
Your second photo shows what GM knew, for the tank to be completely compromised you would have to take a huge hit, as you did, and even with that amount of damage the tank looks intact.
Was the tank ripped or did the fuel come from the filler tube when everything else was shifted?
it ruptured on the passenger side and along the top side of the tank where its seamed together from where the indentation of a tree is on the back side of the cab....if you look at all the pictures and see dark wet spots all over the whole truck on the black primer paint thats all fuel some from filler and some from the inside of the cab! i think picture #4 you can see alot of the fuel on the ground on the passegner side it was like a bomb went off when the tank ruptured gas was every where.
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 04-26-2012, 07:23 PM   #53
Larry64
41 & ditto on the spare
Larry64 is offline   Reply With Quote
Old 04-26-2012, 07:23 PM   #54
AnlaufJohn
If I add my tank, then we're at 41 or 42, right? Well, mine is being repaired right now and then water tested for leaks before being put back in tomorrow.
What is the best way to get rid of the water that doesn't want to pour out? It may get to 60F with 85-90 % RH, so laying it out and hoping for a good hot sun to cook it isn't going to happen. It's too big for my oven, too.
Is time the best solution? Wait for more than 24 hours?
John in Eugene, Oregon
AnlaufJohn is offline   Reply With Quote
Old 04-26-2012, 07:33 PM   #55
K5 Addiction
K5 Addiction's Avatar
It's in place till tomorrow. Just got my keg in the bed. removing the old tank & shaving the old filler neck tomorrow.
K5 Addiction is offline   Reply With Quote
Old 04-26-2012, 07:38 PM   #56
Turkey
Turkey's Avatar
I'm running with a stock tank.
Turkey is offline   Reply With Quote
Old 04-26-2012, 07:44 PM   #57
gimmy 64
drive it down to Cali in july and take the wife and kids to Disy land and when you go home it will be ready. lol
gimmy 64 is offline   Reply With Quote
Old 04-26-2012, 10:07 PM   #58
markeb01
Senior Enthusiast
markeb01's Avatar
A couple of heat lamps focused on the outside would easily cook the tank enough to evaporate any remaining water. I use them all the time for small to medium painting projects and they are really handy to have around. These are the clamp on type I keep permanently mounted over the bench:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 04-26-2012, 10:17 PM   #59
nomrlz
nomrlz's Avatar
guess i'll stay at 44 till we can start on the 5.3 swap
66 LWB/BBW work in progress
68 Camaro SS bigger work in progress
95 Roadmaster Wagon 12.36 @ 107.74
99 Hayabusa 8.72 @ 162
00 Hayabusa 9.33 @ 153
nomrlz is offline   Reply With Quote
Old 04-26-2012, 11:01 PM   #60
cruznfb
cruznfb's Avatar
45.....i plan on keeping it.
cruznfb is offline   Reply With Quote
Old 04-26-2012, 11:06 PM   #61
likaroc13
Rollin' Old Skool
still got mine in the stock location, & no plans to change
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 04-26-2012, 11:12 PM   #62
SIR
SIR
SIR's Avatar
forty seven...
66long low fleet http://community.webshots.com/user/LVNR66
SIR is offline   Reply With Quote
Old 04-27-2012, 12:33 AM   #63
big_rig
Still have mine in there. Undecided of I should move it out back or get a smaller steering wheel... Or lose a few pounds. Haha.
big_rig is offline   Reply With Quote
Old 04-27-2012, 12:45 AM   #64
Touchdown67
Touchdown67's Avatar
forty nine.... I dig the old tanks.
Touchdown67 is offline   Reply With Quote
Old 04-27-2012, 12:47 AM   #65
jbwolfe
49 here, and no plans of change. When I bought the truck, I pull the gas tank out and drained it, and in the process was able to see that the tank is in perfect shape. One thing to be said for tanks being in the cab, they stay out of the weather that way.
jbwolfe is offline   Reply With Quote
Old 04-27-2012, 12:49 AM   #66
Touchdown67
I know what you mean....I just put a 700r4 transmission and a Ididit column in my 65. The new column is great because I was able to mount it about 3 inches closer to the dash. Its nice to have the extra belly clearance. LOL.....
Old 04-27-2012, 01:57 AM   #67
markeb01
Senior Enthusiast
markeb01's Avatar
For some unknown reason my steering wheel has migrated much closer to my six pack abs over the time I've owned the truck. Shortening the steering column and/or using a wheel with a shallow dish is really the most effective way to gain some belly room. Unless a person can tolerate having the seat back straight up vertical, removing the stock tank won't allow the seat to move back any further because the upper part of the seat back hits the bulge just below the back window same as it did with the tank in there.
Old 04-27-2012, 06:11 AM   #68
C-10cutty
C-10cutty's Avatar
50. The rest of the truck is pretty much stock so what the hey.
C-10cutty is offline   Reply With Quote
Old 04-27-2012, 12:06 PM   #69
billd5string
billd5string's Avatar
51
65 C20 Fleetside longbed, 350, turbo 400, 8-lug disc brakes, power steering, air conditioning - Totaled by a guy running a red light. Pulling parts off the carcass for my next truck
billd5string is offline   Reply With Quote
Old 04-27-2012, 01:30 PM   #70
1963c-10
1963c-10's Avatar
The consensus seems to be the majority still have in cab tanks...glad to see.
1964 Short bed trailer
Old 04-27-2012, 02:17 PM   #71
Chevysdominate
Chevysdominate's Avatar
I dont really have a crush on the in cab tank but I happen to live in a state that still doesn't think its citizens can pump there own gas by themselves. I also dont like the idea of lowering the tailgate every time to fill up too. If I could find a good way to get the filler neck accessible without needing to jump through hoops i would.
Chevysdominate is offline   Reply With Quote
Old 04-27-2012, 02:49 PM   #72
CVA59
Mine will also stay in the cab as original.
Zack
www.23t.weebly.com
_________________________________
CVA59 is offline   Reply With Quote
Old 04-27-2012, 04:25 PM   #73
AnlaufJohn
Number 42 here, and a new tank has been ordered. I could not get the welder to follow my instructions, decided he knows and has done more welding than me (never picked up a torch or stick in my life) and the 4 hour water test this morning shows it still seeping. I wanted no water showing.
So, a new tank is the way to go.
New question: what, if any, sealer should I use? I plan on running with Clear 92 octane fuel. A new tank shouldn't need a sealant or chemical liner, or so I think.
Please chime in; I have a few days until the tank shows up.
Eugene, Oregon
Lucy's Limousine
1966 C-10 LWB
283 w/ 2bbl, OE carb and dist.
4 spd (granny 1st) w/ 3.73 rear end
Old 04-27-2012, 08:42 PM   #74
ChevyTruckGuy
ChevyTruckGuy's Avatar
One more here but mine leaks if I over fill it. Been a long time since I drove it though...
1966 Chevy C 20 Lwb (Now a project)5.7 400hp
1996 Chevy Silverado Reg Cab Lwb (Daily Driver) 5.7
2000 Chevy S-10 Ex Cab Lowered 4/4 4.3 (For Fun)
2008 GMC Sierra Ex Cab 5.3 (once a month driver)
Wife's 74 Ranchero 500 351 Cleveland (One Owner)
My name is Mike and im in So. Cal (Hi Desert)
ChevyTruckGuy is offline   Reply With Quote
Old 04-27-2012, 09:41 PM   #75
rideblue00
rideblue00's Avatar
we at 54 then! mine still there, but after seeing losthope crash pics...im rethinking it.
rideblue00 is offline   Reply With Quote
