04-28-2012, 11:28 AM | #351 |
Re : 1969 C/10 250TH Pix
I still can't figure out how you guys put text between the pictures , I'd really appreciate a primer here .
Anyway , here it is , for the person asking about the TH350 T.V. Cable , look at pic # 3 , the bell crank on the intake manifold , the T.V. Cable is attached at the bottom of it , the throttle linkage is barely visible behind the Anti-Diesel Solenoid , just in front of the rockerbox , I hope this helps .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
04-28-2012, 11:34 AM | #352 |
Re: Post Your Straight Six Pics!
Hey Nate, I see you have an offset air cleaner. If you ever want to convert to power brakes, I have some booster brackets...
'69 Fleet It ain't yours, if you didn't build it! |
04-28-2012, 12:01 PM | #353 |
COOL THANKS NATE. GOOD looing SIX THERE
04-28-2012, 12:04 PM | #354 | |
I'm looking for the intake manifold fitting too .
04-28-2012, 02:22 PM | #355 |
I am a Referee of life.
I picked up an intake mani fitting at Advance.I had to look thru the boxes of fittings.I used a 90* one because it made routing my hose cleaner.I used to port on the base of the mani under the carb.The one just in front of your bellcrank arangement or the TV.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
04-28-2012, 11:54 PM | #356 |
THANX ! when I worked in an outlying Heavy Duty Truck Shop , we had all manner of hardware , fittings , stuff to make up custom battery cables , on and on.... more Weatherhead fittings and hose ends than would fill a 40' Semi ~now that's all gone & in the L.A.P.D. Central Garage , it's amazing how they get anything done , all Ford dealer parts I guess .
I'll go give the local FLAPS a look . few seem to stock any Weatherhead these days .
05-13-2012, 02:34 PM | #357 |
Well got the 250 in the 67. Still trying to locate the brackets for the kickdown/tv cable for my th350 setup.
Stovebolt-It is painted |
05-13-2012, 10:38 PM | #358 |
Cruzin
looking great guys
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
05-15-2012, 09:31 AM | #359 |
Nice to see the engine is in place .
You'd best change that tin fuel filter for a NAPA / WIX clear one before you get stranded by diry gas . 3/8" hose size IIRC .
05-15-2012, 10:23 AM | #360 |
Okay sounds good Nate. What do you think about the rubber fuel line that it has right now? All tips and ideas are welcome. I didn't paint it because I had only a day to borrow my neighbors engine hoist because he needed it for a job. Still seeing what i need to replace. I may even buy a new exhaust/manifold gasket kit. But might wait till I fire it up to see how it is first. ALSO I do not know if you can see but where the between the two last spark plug cables hangin there is a orange piece cross type thingy. What is the purpose is it a breather? I can take a better picture when I get home tomorrow.
P.S I am no mechanic but sure want to learn as much as I can before I do start driving this everyday for the rest of my life and get stuck in the middle of nowhere :-P
05-15-2012, 02:09 PM | #361 |
Re : 250 & TH350 IN !
I don't see anything between # 5 & 6 plugs or wires...
Unless the rubber fuekl hose is new by you , it should be replaced . In fact , ther clear fuel filter is supposed to go just before the carby , not on the suction side of the fuel pump like it is now . Folks who don't understand how these things work will errornusly tell you the filter over the manifold is bad , it isn't . Keep plugging away ! you're doing great ~ I just don't like unpainted engines .
05-15-2012, 03:47 PM | #362 | |
cheers mark
1969 stepside-305/4spd/12 bolt posi http://67-72chevytrucks.com/vboard/s...d.php?t=477157 1968 pontiac lemans convertible-350/pwrglde/10 bolt 1934 oldsmobile sedan-350/350/12 bolt posi 1930 model a pickup-350/350/jag ind 1928 model a roadster-283/350/9" |
05-15-2012, 04:11 PM | #363 |
Cool thanks for the help Fellas.
05-15-2012, 05:24 PM | #364 |
mine is a 1970 c-10 292 six with a four speed at this time , going with power steering and automatic later, p/s is first on the list. here are some pics.
05-15-2012, 11:31 PM | #365 |
Looks like you got your cake and ate it too! A/C and an in coil HEI!!!
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
05-16-2012, 12:22 PM | #366 |
Ole dollor that is a nice setup in there. Love the 292.
Note:I ended up getting a new clear fuel filter and am replacing the old rubber part of the fuel lines with 5/16 because thats what it had but you noted that I should have got 3/8? is this okay what I got? I just want to try and do it right the first time around but I know I will fail hahaa. I mean this will be my daily driver for the rest of my life so I am trying to avoid cheap way out.
Stovebolt-It is painted Last edited by 50bomb; 05-16-2012 at 12:30 PM. |
05-16-2012, 12:46 PM | #367 |
longbed67, yes the hei was my first up grade, man it made a big difference, and the a/c is a must for old fat guys in texas...it does not look like much, but almost everything form brakes and suspension are done, power steering is next, then cab mounts, and auto. trans. looks like everyone is still running their 4 blade fan, i put a clutch fan on mine, i change from the 373 rear end gear to a 276 gear. that has given me over 18 mpg.
05-16-2012, 12:49 PM | #368 |
50bomb, thanks for looking, it will be a while before its finished,but i enjoy working on ole dollar almost every day, i installed a inside rear view mirror with map lights yesterday, looks good.....
05-16-2012, 01:04 PM | #369 | |
Thanks, Mark
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
05-16-2012, 02:58 PM | #370 |
That's quite an AC pump bracket. I used an external coil and mounted the pump a lot lower. The dist cap comes off very easily.
I would trim a lot of meat off your bracket, but first mount the PS pump and get the belts figured out. What's wrong with a four blade fan? Works well on my truck, but I did put an electric fan out front. I have 3.54 gears and a truck 4spd. I don't think it would like 2.76 at all. Maybe CA isn't as flat as TX.
'67 GMC 2500, 292, 4spd, AC |
05-16-2012, 03:58 PM | #371 |
Sanden AC compressors ! SWEET .
If 5/16" hose fits O.K. use it . Always try to match the hose to the pipe . NAPA/WIX makes those clear fuel filters in all sizes . Cali. is mostly as flat as TEXAS but we have crappy " Motor Fuel " that's SO bad , by law they're not allowed to call it ' Gasoline ' because it ain't . Please keep those pictures coming ! .
05-16-2012, 08:35 PM | #372 |
On my trip back from Seattle washington to wisconsin I averaged 18mpg with a 3ott and a 3.73 rear. I have switched out to a 3.07 with an eaton posi with 600lb springs and moser axles and am curious to see what I will get! I almost put in the 2.76 gears but opted for the 3.07's but still have them in the box if I change my mind!
05-19-2012, 10:49 PM | #373 |
richardj :yes i will cut the a/c bracket later,make it look a little better, vwnate1 i put the fuel filter before the pump because ole dollar had been on butane for years and the seat tank was full of really bad gas, i drained the tank and put new gas in, that was to catch anything that might have been in the tank, as far as a 4 blade fan goes they are noise and will cost you more in fuel having to pull a straight drive fan.
i got the power steering all put on ole dollar and changed out all the cab mounts, just my luck the old used power steering pump is leaking real bad, but it drives like a new one now, the cab mounts made a big difference in the ride, now when the new pump comes in i will change it out and be happy,happy. i went with the 276 gears on mine , thought about the 308, i think either one would work good, ole dollar will never be use as a tow vehicle, so i am after fuel mileage,i am at around 18.2 mpg right now at 2000 rpm , and 67 mph. it takes off good in first or second. and i have no idea what the top end would be... 70stovebolt i got my gears from a place in lubbock texas, the name of the place is american differential . great people to do business with... |
05-26-2012, 08:11 PM | #374 |
Need help. I still can not figure what this orange piece is for.
05-26-2012, 08:24 PM | #375 |
Does anyone know where I could get a nice new fan guard like the ones I'm seeing on a few truck in the 2 straight six threads? I've looked online, and in the various catalogs I have, but--unless I'm calling it by the wrong name--no dice.
Thanks. |
