Old 04-28-2012, 03:12 PM   #1
gramps77
bolt in lowering shackles
I had tried these shackles http://www.autozone.com/autozone/acc...er=204654_0_0_
awhile ago and took them back because the were about a half an inch to narrow and wouldnt fit without severe force.
What are you guys using that bolt RIGHT IN?
gramps77 is offline   Reply With Quote
Old 04-28-2012, 04:43 PM   #2
88Jimmy4x4
88Jimmy4x4's Avatar
Re: bolt in lowering shackles
no matter what brand you have to notch out the metal on the bottom of the bed support but I always use belltech
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 04-28-2012, 05:59 PM   #3
rwhit57
rwhit57's Avatar
Those are probably 88-up. Just get the right ones.
"Whoever said money can't buy happiness has obviously never seen a speed shop!
rwhit57 is offline   Reply With Quote
Old 04-28-2012, 07:40 PM   #4
gramps77
No issue at the bed support. Im talking they were literally not the right size to fit with the leaf spring.
I was also wondering if it being a "heavy half" ton would habe anything to do with it. Would I have wider springs or are there just more of them?
Old 04-28-2012, 08:20 PM   #5
88Jimmy4x4
88Jimmy4x4's Avatar
oh the heavy half may be your issue, how wide are your leafs?
1991 GMC Jimmy 4x4
Old 04-28-2012, 08:28 PM   #6
USSkoval
Heavy Half or not, the rear springs were all the same width, 2.5 inches. Probably just cheap shackles.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 04-29-2012, 02:52 PM   #7
gramps77
USS was right, 2.5 inches wide......I suppose I'll get some Bell Techs.
Those seem to be the ones everyone uses.
