04-29-2012, 01:38 PM | #1 |
HELP...Please post some pictures your brake lines!!!
Hey guys, there are alot of things I can do but one experience I have not had is brake lines. The fabrication I am not concerned about because I am a pretty darn good plumber with most any type of hose or line. Unfortunately, I lack the experience to have clever ideas to make it look pretty. I will have a pretty detailed frame and want it to look nice. I will have 4 wheel disc brakes, Porterbuilt Dropmember and C-Notch. Pictures, ideas, advise, manufactureres you recommend. Please help me, I have falled and I can't get up!!
04-29-2012, 02:18 PM | #2 |
Re: HELP...Please post some pictures your brake lines!!!
here's a pic of mine (before/after) from the mc to the frame rail anyway... Granted you'd have a diff mc and a booster probabaly, along with a prop valve, but, this is home made at the very least.
04-29-2012, 08:43 PM | #3 |
bump
04-30-2012, 03:01 AM | #4 |
I used straight 3/16 stainless lines and used JIC/AN style 37 degrees fittings. As far as Im concerned, other than in a all original restoration the 37 degree set up is the way to. Only needs a single flare, doesn't leak and can be loosened and re-tightened many many times w/o losing it ability to seal. Also gives you alot of options with things like passing through crossmembers. Heres a few pics of my truck.
04-30-2012, 03:05 AM | #5 |
oops, heres the pics.
04-30-2012, 09:11 AM | #6 | |
I must ask...where did you purchase the stainless steel lines and the bulkhead fittings? |
04-30-2012, 09:48 AM | #7 |
www.inlinetube.com sells compelete kits prebent with the proper fittings on them for line 155 dollars
04-30-2012, 12:48 PM | #8 |
Ss
1969 Chevy c20(Miss Hackjob) |
05-02-2012, 01:17 AM | #9 |
Got the lines from mcmastercarr.com and the fittings from anplumbing.com. Borrowed the 37 degree flaring tool from a friend, brand name was rigid.
05-02-2012, 08:41 AM | #10 |
duh, damn I get all kinds of stuff from McMaster Carr and didnt realize they had the tubing. They are an awesome souce of fasteners
05-03-2012, 07:18 PM | #11 | |
