Old 04-29-2012, 10:28 PM   #1
texasbigbear_wink
texasbigbear_wink's Avatar
Where to get a stock 350 prom chip ect.
Can I just go to a junk yard and pull a 87-95 350 prom or is there some matching I need to do. The truck had a 305 but now has a new 350 in it with headman headers, Edelbrock performer tbi intake, 350 injectors, and is currently running on the stock 305 prom chip. I have a jet prom chip I ordered for it but I feel its not working out to well for it.
87 Chevy R10 LB
02 Nissan Sentra GXE
texasbigbear_wink is offline   Reply With Quote
Old 04-29-2012, 10:31 PM   #2
texasbigbear_wink
Re: Where to get a stock 350 prom chip ect.
Link to my build: http://67-72chevytrucks.com/vboard/s...d.php?t=449496
87 Chevy R10 LB
Old 04-29-2012, 11:33 PM   #3
makman1297
makman1297's Avatar
I did a swap in my fater in laws truck, just pulled a chip from the junkyard with a 350 and matching tranny. The 95's are different so do want one of those unless your whole system is 95. Also know that you will need to change the knock sensor and knock sensor controller if you have one, small black box next to you tbi to go with the 350, the 305's are different.
1981 Dodge D-150 (under construction)
2007 Chevy Suburban
2010 Dodge Charger R/T
1980 Kawasaki KZ 440
2004 Harley Sportster 1200
makman1297 is offline   Reply With Quote
Old 04-30-2012, 12:42 AM   #4
sierra4x4
sierra4x4's Avatar
Make sure you use a prom from a ecm that has the same service number. I think the last 4 digits are 7747. I think 87-91 or 92.
sierra4x4 is offline   Reply With Quote
Old 05-05-2012, 11:45 PM   #5
texasbigbear_wink
Thank's men. I changed the know sensor when I put the motor in but did not change the knock sensor controller I will check in to that. My truck has a TH 400 trans in it I hope that I can find and ecm and prom with the 350/TH400 in it .
87 Chevy R10 LB
Old 05-05-2012, 11:47 PM   #6
texasbigbear_wink
Just got it all back together know I can not wait to get it running good.
87 Chevy R10 LB
Old 05-05-2012, 11:58 PM   #7
walkerscott
does the 350 have stock cam..
walkerscott is offline   Reply With Quote
Old 05-06-2012, 12:11 AM   #8
texasbigbear_wink
Yes, Its a rebuilt 350 nothing but the headers, intake, Serpentine belt kit added and dual 40's flows dumped before rear.
87 Chevy R10 LB
Old 05-06-2012, 07:25 PM   #9
texasbigbear_wink
Ok today I added a new Electronic Spark Control Module and Map Sensor and put the jet performance chip/prom back in and it still runs the same. It will
idle fine but when you turn the AC on it will bog down or when your driving it and goose it the truck will go but will hesitate and feels like it don't have the power it should. Could it be the coil,TPS or something els? Also setting idle for a 5 min or so it will just die.
87 Chevy R10 LB
Old 05-06-2012, 08:51 PM   #10
Jonboy
Slots go on anything!
Where is your timing set? I had a problem withteh way the distributor was clocked; it was putting presure on the ESC plug and missing intermittently. I restabbed the distributor (plugs at about 2:00), and reset timing at 0 with the tan wire unplugged. Problem solved.
1974 Jimmy- 5.3/4L80e/NP241
Jonboy is offline   Reply With Quote
Old 05-06-2012, 09:25 PM   #11
texasbigbear_wink
Hum mine is facing directly at the fire wall the plugs that is but with the brown wire disconnected the timing is 4 deg off.
87 Chevy R10 LB
