Fan Removal?
Starting to remove all external parts to a 2002 5.3L to prep for paint. I'm finished except for removing the fan clutch from the waterpump. How do you remove it?
Thank you, Kevin C
1988 C1500 Regular Cab, Long Bed, 2WD. |
Re: Fan Removal?
Takes a special tool. It's a fan clutch wrench.
Be sure and get the tool that holds the pulley that the belt rides on also. There are two small holes in the front of it that the tool fits in to hold it. I borrowed one from Auto Zone to get mine off. Kim |
![]() Join Date: Dec 2007
Re: Fan Removal?
I used an oil filter wrench with a rubber strap and a larg crescent. Hold the filter wrench tight on the water pump pulley and hit the crescent with a rubber mallet.
1950 Chevy 3100 Ramp Bed 1-ton http://67-72chevytrucks.com/vboard/s...d.php?t=749386 1965 Chevy Step Side 1971 Chevy Short Wide Bed http://67-72chevytrucks.com/vboard/s...d.php?t=277191 1971 Chevy C-30 1-ton 1971 Chevy Chevelle 1972 Chevrolet C-30 1 ton 2005 Dodge Ram 2500 5.9 Cummins 2017 Fleetwood Pace Arrow 35M motorhome 350 Cummins 2020 Jeep Wrangler Unlimited Rubicon |
Re: Fan Removal?
If you get one that just won't budge, an air chisle works great!
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
