Old 04-30-2012, 05:50 PM   #1
zenchal26
zenchal26's Avatar
Steering issues pleas help.
Anyone running 3" monos and 3" drop axle? My drag link hits the axle way before I hit the steering stop. What have you done to correct this problem.
zenchal26 is offline   Reply With Quote
Old 04-30-2012, 07:45 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Steering issues pleas help.
You can get another arm and bolt it to the top.
Heat and bend the arm into position that clears the bean. lop off the front arm part of the original and the rear arm part of the new top one. So you end up with a lower with no front arm and an upper with no rear arm.
Leave both arms intact until you get the upper arm bent correctly.
Old 05-01-2012, 10:11 AM   #3
zenchal26
zenchal26's Avatar
Wont I have bump steer issues beacuse the drag link will be no where near level?
Old 05-01-2012, 10:48 AM   #4
mr48chev
mr48chev's Avatar
Most likely you would have a bit of bump steer. Can you heat and bend the stock steering arm up just enough to get clearance? It may only take moving it a half inch or so along with repositioning the adjustment sleeve so that the bolts are at the top and out of the way. I'd have to go look under my truck but I believe that on a stock steering the end of the drag link is on top of the steering arm rather than below it. I think that may be your real problem that was created in an attempt to get the drag link level.
Old 05-01-2012, 01:08 PM   #5
robin58
If you were to convert to power steering it would be relatively simple as most aftermarket suppliers sell pitman arms for dropped trucks.
But I'd guess there's no reason you can't follow the same kind of principle and keep a manual box.
robin58 is offline   Reply With Quote
Old 08-22-2012, 07:57 PM   #6
zenchal26
zenchal26's Avatar
just put drag link in press and bent it a bit worked perfect.
Old 08-23-2012, 12:30 PM   #7
_Ogre
_Ogre's Avatar
where there's a will, there's a way
good work
shop air compressor timer
