05-04-2012, 09:31 PM | #1 |
DND Trucks
70's Motor Home Tilt
Here's a late 70s MH auto tilt column for sale. Tilt mechanism is tight and the shift bowl pin area for the gear selector isn't oval shaped, like a lot are. Item also has the correct length shaft and long style gear selector. Tilt and and cruise lever are included. Take a look at the pictures, some surface rust near the bottom of the column.
Great column to convert to a 69-72 truck tilt. 175.00 shipped CONUS. |
05-05-2012, 10:41 AM | #2 |
DND Trucks
Re: 70's Motor Home Tilt
ttt.
05-06-2012, 06:09 PM | #3 |
DND Trucks
ttt. I'll post more pics tonight.
05-06-2012, 10:22 PM | #4 |
DND Trucks
More pics.
The wiring harness was taped up so I unwrapped it to see if there were any issues. None found. The gray wire has the connector missing. I can put the correct connector on it, prior to shipping. Lmk, if you have any questions. |
05-06-2012, 11:07 PM | #5 |
DND Trucks
ttt.
05-07-2012, 06:40 AM | #6 |
DND Trucks
With everyone looking at this, I'll lower the price a bit to get it moving.
160.00 shipped CONUS. |
05-07-2012, 12:36 PM | #7 |
I am interested. I have put the van tilts in trucks before and was not happy. THey worked OK, but I didn't like having to work with the neutral safety switch. What doe the motorhome tilt have to have to make it work in a truck? Do you also have an adaptr to go from the flast plug to the round for our trucks?
05-07-2012, 01:32 PM | #8 |
05-07-2012, 04:56 PM | #9 | |
DND Trucks
05-07-2012, 05:00 PM | #10 |
DND Trucks
05-07-2012, 05:02 PM | #11 |
I'd do it for $160 shipped if the other guy passes.
Do you know if the lower bearing is any good since it has quite a bit of corrosion down there? |
05-07-2012, 08:30 PM | #12 |
DND Trucks
05-07-2012, 08:55 PM | #13 |
Hi Dave,
Money sent for tilt. Thanks, David |
05-07-2012, 09:08 PM | #14 |
DND Trucks
Payment rec'd already. Thanks again.
05-07-2012, 11:47 PM | #15 |
I got skipped. What gives?!
Posted via Mobile Device |
