Old 05-07-2012, 11:38 AM   #1
AngryPirate
AngryPirate's Avatar
new dual master cylinder leaking at the lid
I've tried making sure the rubber gasket thingy is seated properly and the clips are obviously snapped on but it still leaks fluid out of the lid/casting seam.
Ideas how to get this sealed up? It's a friggin' new MC and I really don't want to send it back and re-bleed the brakes.
Thanks,
Scott
AngryPirate is offline   Reply With Quote
Old 05-07-2012, 12:37 PM   #2
66GTO66C10
66GTO66C10's Avatar
Re: new dual master cylinder leaking at the lid
It may sound elementry, but I found the spring clip that holds the cap on sometimes too lose. If you put a little more of a bend in it that some times resolves the issue.
Good luck.
1966 Chevy C10 frame off resto (In progress)
1966 GTO Numbers matching original
1989 Toyota Pickup (Tonka) resto
2002 HD FLSTC
2000 HD FLSTC
1996 Ninja ZX11
Believe nothing of what you hear, and 1/2 of what you see!
66GTO66C10 is offline   Reply With Quote
Old 05-07-2012, 03:18 PM   #3
AngryPirate
Good luck.
I'll give it a shot.
Thanks.
Old 05-08-2012, 09:26 PM   #4
dar130
I had the same thing with my Master cylinder.
I installed disc brakes on the front, with a new MC. It turns out the parts store sold me, by mistake, the wrong MC.
Check the parts number and be sure it is the correct one.
I had one that was for disc brakes on all 4 corners.
dar130 is offline   Reply With Quote
Old 05-08-2012, 09:31 PM   #5
AngryPirate
I picked it up from classictruck.com but it also doesn't call out drum or disc brakes (as you suggested looking up). Classictruck.com just specifies it will work for my year.
http://www.classictruck.com/product/...ster_Cylinders
I'll dig into your suggestion a bit more.
Thanks!
Old 05-08-2012, 10:04 PM   #6
Gianyveedub
Gianyveedub's Avatar
I had the same issue, I replace the rubber gasket thing and it solved the problem.
Gianyveedub is offline   Reply With Quote
Old 05-08-2012, 10:15 PM   #7
AngryPirate
How'd ya know which gasket to get?
Was the replacement thicker? The gasket should be new, but perhaps it sucks? ;-)
Old 05-17-2012, 11:24 PM   #8
AngryPirate
So I tried bending the master cylinder clip ends a little higher up to shorten the clips to create a tighter closure on the lid and it did stopped the leaking.
Just an fyi for others who are having the same issue. I'm sure a bit thicker gasket would've accomplished the same thing.
Thanks for the responses.
