05-07-2012, 01:18 PM | #1 |
tranny question (need help)
will running your motor at an idle in the drive way, not driving it, burn out your transmission if it doesnt have enough fuild in it? both my buddy done the street has had an issue with his transmission. when he first started putting the truck together and then was able to get the truck running he would start is up and let it run, once forgetting to take the truck out of drive and running it into the wall of his garage. fast forward he got is complete enough to try to drive it, he filled it up with fuild and started it and put it into drive but nothing happen. so we though he had burned it up. so he got another used trans that his buddy told him it was a good tranny and he put it into the truck this weekend. then he filled it up with fuild and the same thing happen again, no movement at all. so the question is what are we forgetting to do? what should we look for?
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
05-07-2012, 01:21 PM | #2 |
Re: tranny question (need help)
Drive shaft maybe? if your drive shaft spinning then maybe your differential?....... but im no expert
"So she said, "Either I go or the truck goes!"....Hmm, I wonder what she's doing these days?" |
05-07-2012, 01:33 PM | #3 |
Im guessing that your talking about an auto trans?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
05-07-2012, 02:43 PM | #4 |
Location: I live in Honolulu but my truck is being restored by 4-5-6 Trucks in Kansas City
Sorry, this post will not be of any help to you, but this thread was right below the thread titled "Other help for dating" and it just didn't look right to me, so I'm moving this one to the top.
Posted via Mobile Device |
05-07-2012, 03:28 PM | #5 |
yep sorry I should have given more info, everything is hook up, this is a 350 automatic transmission. when motor is running and trans is in gear nothing happens (no movement)
05-07-2012, 03:47 PM | #6 |
Not enough fluid or possably broke the pump by not having the converter in all the way. Check to see if the pump is working by checking the fluid level with the engine not running, should read over full an inch or more. Start the engine and check again, fliud level should drop to near the full mark. If it drops the pump is working, could be the converter itself. If it doesn't drop, probably broke the pump. If it was run long enough without enough fluid, it could have ruined the pump.
