#76 |
Re: Cherubs Burban Project
Also forgot i got Exhaust installed awhile back. Dual 3" from header back to 24" magnaflow mufflers then all the was your to exit behind the rear tires. Its fairly quiet like i wanted. It doesnt give any drone when cruising or at idle but still has a throaty sound. let me see if i cant get a audio of it.
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) |
#77 | |
#78 |
just dropped the burb off to get the a/c fixed........ Its going to be nice to beat the houston heat!!!
#79 |
Sweet burb.
___________________ 78 ccsb dually 5.3 4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=491551 |
#80 |
#81 |
Technically it has yet to really put in any work but i optimistic that the A/C shop will get the job done and the rear and main A/C will work properly
#82 |
When both A/C's are working properly on these Suburbans, they really do a good job cooling down the huge cabin even at 100 degrees. By the way, if the shop is converting the system to R-134A, make sure they change out the condenser for a newer type parallel flow condenser. The newer type of condenser transfers heat better which is needed when using R-134A.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
#83 |
Garage wrench
Awesome man!! Thanks!!
-Adam 90 V1500 GMC Suburban 350/700R4/NP241..... 01 Saturn SL1 stock DD..... |
#84 | |
One other concern i have though is with the compressor. Ive read on here that this style has a tendence not to last very long. [IMG]removed[/IMG]
2014 LTZ Z71 Silverado 82 C15 LQ4/4L80E Conversion 78 Suburban build (SOLD) 83 4x4 Suburban(SOLD) 82 C15 (my first truck) Last edited by Josh; 06-26-2014 at 10:40 AM. Reason: malware in linked image |
#85 |
#86 | |
Also, just having the system converted, doesn't guarantee that they had a better condenser installed. Having a parallel flow condenser vs the stock tube and fin makes the r134 work almost as well as a vehicle that was designed for it.
1995 Suburban K2500 454.....off road & towing 1999 Astro, work van 2006 Silverado 2wd 5.3 w/4.5" lift and 33s |
#87 | |
#88 |
ill have a look when i get it back.
#89 | ||
#90 | |
Got it from here. Part #7-3642. Autozone supposedly carries the part, but every one here had a box with the correct part # on it, but the part inside was a piccolo style condenser. It fit, but doesn't work as well as a parallel flow. Told autozone that they are selling a part that isn't what they say it is, but they didn't seem to care.
#91 |
well i got the suburban back this morning and its running the old style condenser. I talked to the A/C guy and he said he wouldnt worry about it and wouldnt change it unless i get a leak or something. So ill just stick with what i got. Im fixing to test how well it cools on my way home.
#92 |
Here is some updated pics
#93 |
Wow, very nice looking Suburban. You've got good taste. Those are very nice looking wheels.
#94 |
Looks great. How did the A/C do?
#95 |
nice! lookin good man!
My dreamride / project:1977 GMC C15 Suburban In storage: Monster - 1974 GMC Suburban 25hundred Sold : Chevrolet Suburban K20 Silverado 1986 Guide: real HID projectors for 4x6 headlights link: DIY LED TAILLIGHTS |
#96 |
Looks great!!
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
#97 |
turned out great has good air flow and temp........when i got home my wife was like wow your face is all cold
#98 |
yeller
I love this thing
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
#99 |
Nice rig. Been thinking about doing a 2wd Sub after the dually is done.
#100 |
Let me know if you ever want to sell it....
