Old 05-07-2012, 09:14 PM   #1
chevychase
chevychase's Avatar
Question Pics of lowered trucks with stock A/C boxes?
Just trying to see how low you can go and still keep the stock a/c box on a 73-87. Those lowered with stock a/c can you post a pic of your ride along with your wheel/tire and drop amount? THANKS!!!
Joe
chevychase is offline   Reply With Quote
Old 05-08-2012, 02:55 AM   #2
Square_78
Square_78's Avatar
Re: Pics of lowered trucks with stock A/C boxes?
Mine is down 6/8 (at ride height in the rear - air shocks)and I havent even removed the inner fenders. How is the AC box affected? I have factory AC but it doesnt work. Is there something inside the fenderwell that I am missing on my truck? I guess if you are trying to run 26" wheels and have your inner fenders removed?
My front tires are 215/70R15, and my control arms hit the ground before my tires hit inside the fenders....
Square_78 is offline   Reply With Quote
Old 05-08-2012, 05:05 AM   #3
andrewmp6
Vintage air makes a ac kit that puts everything under the dash.
Old 05-08-2012, 08:40 AM   #4
LOW1TON
Here you go, full air ride with 3" drop spindles on front, custom front inner fender wells, sits flat on front cross member when laid out, tire size is a 265/35/22, running factory a/c heater box that has been moved up on fire wall approx 1-1/2". a/c and heater work perfect! Pictures below.
"WIDER IS BETTER" (TRUCKS ONLY)
LOW1TON is offline   Reply With Quote
Old 05-08-2012, 06:36 PM   #5
Square_78
Square_78's Avatar
Nice setup!
Old 05-08-2012, 06:48 PM   #6
Jesse18873
How hard was it to move up the factory a/c box? And any tips or tricks that you might wanna share? I'm getting ready to bag a dually and moving up the factory box would be a better option than dishing out more money for Vintage Air
Jesse18873 is offline   Reply With Quote
Old 05-09-2012, 09:08 AM   #7
melks
melks's Avatar
setup looks great, diggin' the panels on the underside of the hood!
1984 Chevrolet C10
melks is offline   Reply With Quote
Old 05-09-2012, 09:13 AM   #8
LOW1TON
Not really a big deal took it all lose, trimmed the firewall and moved it all up and re attached. seems like there was enough slack in all the factory components to move up, you can see in the pictures about how far we moved it based on the top edge of the cowl.
Old 05-09-2012, 10:02 AM   #9
1bad87
1bad87's Avatar
x2 where u get them ?
1bad87 is offline   Reply With Quote
Old 05-09-2012, 10:20 AM   #10
LOW1TON
Made them from aluminum, used a bead rolloer and dimple die. Made patterns from consrtuction paper and tranferred it to sheel aluminum. cut them out and bead rolled them drilled holes then used dimple die. When finished I scotch bright pad brushed the finish.
Old 05-09-2012, 10:56 AM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Here's what mine looks like on my 77 Cheyenne.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-09-2012, 10:58 AM   #12
N2TRUX
Happy to be here
N2TRUX's Avatar
And this is how low it goes..
Articles-
"Refining Sierra"
Old 05-09-2012, 12:17 PM   #13
JCampbell
I don’t think you’re going to have any issues with your standard, run of the mill drop job on mild wheels (< 22”). My dually is dropped 6” up front (3” spring, 3” spindle) on a 225/75/16 (29”-30” o.d.) and I don’t have any issues, although I did pull my inner fenders.
You really only start to see the interference issues on bagged and bodied trucks running big wheels (> 22”).
JCampbell is offline   Reply With Quote
Old 05-09-2012, 04:01 PM   #14
1bad87
1bad87's Avatar
dam nice truck inside pics!
Old 05-09-2012, 06:33 PM   #15
Jesse18873
Thanks for the info. I already have 3" spindles and pretty soon adding the air ride as soon as everything comes in. Trying to see what my stopping point will be. Either laying on front crossmember or frame with a 22" wheel
Old 05-09-2012, 06:36 PM   #16
Jesse18873
Oh btw, were you able to use your existing heater outlets?
Old 05-09-2012, 10:52 PM   #17
chevychase
chevychase's Avatar
Thanks for all the replies guys, I've got a "much" better perspective now. Pretty slick raising the a/c box!
Joe
Old 05-10-2012, 08:17 AM   #18
D.FENS
You didn't say how you were going on the air ride - Porterbuilt makes tubular lower control arms that move the front wheels forward slightly (don't know exactly how far).
Centers them up in the wheel well and helps get the tires off the A/C box at full drop.
D.FENS is offline   Reply With Quote
Old 05-10-2012, 09:49 AM   #19
chevychase
chevychase's Avatar
Good point. I was thinking of raising the crossmember up into the frame 2" (like the JT truck in the make it handle thread) and either move the crossmember forward to center the wheels OR have Nate make some arms.
Joe
